The "cheap fix" is the blower resistor, which most of the time is the reason for a failed motor. However, the climate control system does not use a blower resistor, and instead uses a fancy module that controls the fan speed. I dont know if your system ever worked, but you would notice it when AUTO mode kicks in and how the fan speeds up smoothly, as opposed to a 1, 2, 3 and 4 speed setting. This is done by PWM, a method that is more functional and efficient than using a set of resistors to select motor speed, but alas more expensive.
That said, the easiest way to start diagnosing is you have to measure the voltage at the blower fan under/behind the passenger glovebox. If you have voltage present when a fan speed set to max, then your blower motor is bad. around 50 bux for a new motor. If there is no voltage present at the motor, it could be a whole plethora of things. The fact that the control panel lights up most likely rules it out, leaving culprits being the AC amplifier, Motor controller, Motor, or a bad connection. Best start checking out the motor.
Click that cool picture above for my cardomain!
