stalling and jumping rpms
this is my first post, i hope i am in the right spot?
bought a 1997 Avalon a few weeks ago and it just started having 2 problems, (at the same time)
1. when shifting from park to reverse, it stalls. doesnt matter weather its warmed up or not
2. when cruising and i let off the accelerator, the rpms drop, but then jump up and down (+/- 500rpm) before settling
-i cleaned the air intake, air filter, throttle body and MAF with appropriate cleaners. no change
-i plan to change the fuel filter, if that doesn't work;
-i plan to change fuel pump, (should i have fuel pressure tested before i replace the fuel pump?)if that doesnt work,
-maybe its the Idle Air Control Valve?
-maybe its the Map Sensor?
Any help will be GREATLY appreciated! thanks
