Gear shift light - Dash fuel light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2010, 09:38 AM   #1 (permalink)
View YSquared's Photo Gallery
Gen1 Gear shift light - Dash fuel light
Hey Folks. I'm getting my recently purchased 1997 XL back to fully functional condition. When driving at night I noticed the internal dash light on the fuel gauge side is out. Any suggestions on how to replace?
Also ... Does the center console under the auto trans gear indicators light up? Don't know if it's burnt out as well, or if you're just supposed to use the indicators in the dashboard cluster to see what gear it's in.
Any help would be appreciated.
YSquared is offline   Reply With Quote
Old 12-20-2010, 10:26 AM   #2 (permalink)
Avy
Gameroom cash: $821455
View pmesfun's Photo Gallery
You will have to remove the gauge and replace that bulb.
The gear shift indicator is supposed to light up. I had that same problem, just slowly pry up on each corner and try not to break the clips.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 12-21-2010, 10:01 AM   #3 (permalink)
Thanks for the bulb replacement info on the gear shift indicator. Any advice on how to get to the fuel gauge bulb?
Old 12-21-2010, 03:33 PM   #4 (permalink)
View ottogaus's Photo Gallery
Fuel gauge bulb is accessed by removing the instrument cluster (which is preceeded by removing the trim panels around it). Hope this helps. By the way, the bulb that lights up the gears near the shifter is something I had to replace. Seems you can only get the bulb from Toyota, and the bulb comes with its own "condom" that fits over the top to make the bulb not as dark.
ottogaus is offline   Reply With Quote
Tags
dashboard light, transmission indicators
