EGR System malfunction - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2010, 04:05 PM   #1 (permalink)
View smallstar's Photo Gallery
Is it possible to clean an EGR valve that is messed up?, (sending bad code to the ECU).
smallstar is offline   Reply With Quote
Old 12-21-2010, 04:14 PM   #2 (permalink)
Tech1984's Avatar
Gameroom cash: $256350
View Tech1984's Photo Gallery
Seldom, but on top of it, the EGR position sensor go bad more frequently. What's the code??
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline   Reply With Quote
Old 12-21-2010, 05:49 PM   #3 (permalink)
Bad egr
It's error code 71
Old 12-21-2010, 07:05 PM   #4 (permalink)
Tech1984's Avatar
Sorry, I don't list a code 71 for a first gen Avalon\
Should be P0401 EGR insufficient flow detected
2010 Camry LE 2.5
Cheers!
Old 12-21-2010, 07:54 PM   #5 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281592
View csaxon's Photo Gallery
Code 71 is EGR system malfunction . What year is it?
If EGR gas flow is low due to the valve or passage restriction, the temperature will also be low, and computer will set code 71.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 12-21-2010, 08:08 PM   #6 (permalink)
You can clean the hoses and orifices but the problem may be a torn diaphram. What symptoms are you experiencing?
