Power Antenna Repair - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2010, 12:12 AM   #1 (permalink)
View awicks's Photo Gallery
Got 96 and antenna doesn't move at all. Any suggestions on troubleshooting? Does that mean bad motor or new antenna all together? As I'm typing this it hit me that may be a fuse so I'm going to check fuses. But a little weird that I don't hear motor or anything when turning on radio.
Saw this ebay listing
http://cgi.ebay.com/ebaymotors/OEM-P...mZ300505872774
and have heard about the s2000 and shark attack replacement ones so any thoughts there would be appreciated
awicks is offline   Reply With Quote
Old 12-23-2010, 12:39 PM   #2 (permalink)
Sir Loin of Beef
Jack Deth's Avatar
View Jack Deth's Photo Gallery
1st on the list is to check for power. you can try a little wd-40 on the mast in the retracted position, it may be sticky. otherwise, you are in the position of having little to lose. pull it apart and see what there is to see. it likely has a limit switch that may be corroded.
Jack Deth is offline   Reply With Quote
Old 12-23-2010, 04:43 PM   #3 (permalink)
View doverville's Photo Gallery
Another common thing to go wrong on these power antennas is that the mast breaks. So while the power is running and the gears turning, it's not actually connected to the antenna. The mast is the plastic toothed "thingy" that is inside the antenna and is fed through the gears to raise and lower it. It's kinda like a motorcycle chain. If the chain breaks you can rev the engine all you want, but it wont turn the tires.
I have used one of those replacement masts off ebay before and it worked fine. Lasted about three or four years i'd say before it broke again. This was on a 4runner though.
If Jack Deth's advice doesnt fix it then I"d try removing the antenna and making sure it is intact.
doverville is offline   Reply With Quote
Old 01-06-2011, 08:55 AM   #4 (permalink)
First rule...make sure it's plugged in
Plugged in and the motor clicks so I think the mast thread is broken but after reading the threads it seems like it may be easier to just replace whole antenna...found this on amazon for 30 bucks anybody have any experience with this one as far as fit and reliability?
http://www.metraonline.com/part/44-PW22
Old 01-07-2011, 02:01 PM   #5 (permalink)
it's extremely simple to replace the mast - takes about 5 minutes and the instructions come with the part.
