Man, this thread has just so many abbreviations, its crazy! Anyway, theres not much activity in this forum section and I thought I'd post my progress on my HVAC center while I'm waiting for glue to dry.
My old modifications, over a year old were starting to fail. I guess I built my voltage regulator at too high of a voltage.
Split that HVAC unit open, Yumm.
I drilled holes into the diffuser to fit the 5mm leds into, and used tinfoil to help these super effcient optics
Glue of choice, support your own economy, dammit!
It sets quick, yet I would like a higher initial viscosity, too runny for such a small application.
Similar approach to how I did my instrument cluster lighting. Uses a lot of LEDs though!
If there is something different I would do here, is to raise the LEDs by a 1/8 to a 1/4 of an inch.
Results are pleasing so far.
thermostat dial, glue needs to dry then I can begin soldering.
Same story with the glue.
EDIT: Glue dried on some parts! (or well, dry enough for my low standards!
Then again, I'm probably the only one on new-years eve drilling holes in their car to install more lights!
EDIT: Its done enough!
