OBD-II Codes and Smog - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2011, 02:52 PM   #1 (permalink)
View Jeru's Photo Gallery
I have a 1998 Toyota Avalon.
After my check engine light came on I got two OBD-II codes. One code was a bad air/fuel ration sensor, the other code was a random misfire in cylinder 2.
After replacing the a/f sensor, disconnecting the battery for about 45 minutes, the check engine light was gone.
Will my car still fail a smog test due to the random misfire code, even though my check engine light has turned off? In other words, is the presence of any OBD-II code mean a smog failure?
Thanks,
Jeru
Jeru is offline   Reply With Quote
Old 01-08-2011, 10:41 AM   #2 (permalink)
Sir Loin of Beef
Jack Deth's Avatar
View Jack Deth's Photo Gallery
i know it will fail if the light is on, but i don't know about in memory.
d/c the battery should have erased the codes. the codes in memory will be erased after a certain number of starts, too - so if you have some time before the test the problem will likely take care of itself. if you have a code reader that will clear the codes, do that. if you bought the replacement part at a local store that reads the codes for free, bring the car there and ask them to check/erase the code.
lastly, call your states emission test department and ask them, the regs vary by state.
Jack Deth is offline   Reply With Quote
Tags
check engine, misfire, obd, sensor, smog
