Can anyone tell me what this light means?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2011, 09:54 AM   #1 (permalink)
View jrobwitt05's Photo Gallery
This light popped on yesterday, I do not have my owners manual...I have checked all my lights and it appears all are working...can anybody tell me exactly what this light means?
thanks in advance
http://www.google.com/imgres?imgurl=...ed=0CDEQ9QEwBA
1998 Toyota Avalon XL
jrobwitt05 is offline   Reply With Quote
Old 01-13-2011, 10:17 AM   #2 (permalink)
Avy
Gameroom cash: $821455
View pmesfun's Photo Gallery
It saying one of the stop/tail/side markers are burn out. Also, check the 3rd stop light.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 01-13-2011, 09:01 PM   #3 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132150
View Jigg007's Photo Gallery
It means your nitrous oxide system is ready to go! Once that baby hits 88mph you're going to see some... burnt out tail lights.
Yeah, what pmesfun said, its a taillight malfunction indicator, fancy talk for you have a funky bulb in your tail lights. I believe mine went on with a reverse light, that was a tricky. one.
I'd just pick up four 1157 lights, and four 1156 lights, and replace them all. Even at a NAPA that wouldn't go over $10. Beats replacing one faulty bulb, then having another bulb fail in a month.
I think the CHMSL (the third brake light) is the 921 bulb, also 99 cents.
~To remove the tail lights~
Pop open the trunk lid.
There are two 10mm bolts on the tail light which the trunk lid covers, remove them.
Then with sort of a bumping motion, bump the lamp with your palm towards the side of the car. theres a little diagram showing whats up on the lamp fixture.
Once removed, the sockets simply twist out. All the sockets are similar size, I recommend removing one at a time.
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
Old 01-24-2011, 03:21 PM   #4 (permalink)
View sonic2wb's Photo Gallery
Annoying little light! all my bulbs work and it still comes on if i have my foot on the brake too long i replaced all stop lamps but the 3rd tail light (its working) but i think thats my issue
sonic2wb is offline   Reply With Quote
Old 01-24-2011, 09:54 PM   #5 (permalink)
Avarollin?
Jigg007's Avatar
It is clearly your 3rd brake light, CHMSL then. The warning bulb will only come on if the suspect bulb is used. Either that or you have some cruddy wire harness/socket connections. But change the CHMSL bulb and I'm sure your problem will go away!
Old 01-25-2011, 12:09 PM   #6 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
I See a LOT of times if the light comes on with the CHMSL(when you put your foot on the brake pedal) then you've got the wrong watt bulb in there. There are a few different bulbs that look right but use a different wattage. They draw the wrong amount of current and trip the light.
Just make sure you get the correct bulb for that location. 1st Gen Avy's are notoriously picky about them.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 07-11-2011, 09:17 AM   #7 (permalink)
View slick371's Photo Gallery
Just came across this thread. I have a 95 Avalon and occasionally get this same warning light. The light will come on, stay on for a couple of days and then go off. It may not come on again for several months. I've checked the bulbs and they are good. I need some help trying to figure this out. I'm thinking it may be a bad brake light switch. Anyone have any ideas? How do I test the switch to determine if it is the problem?
Also, I have a problem with my shift lock system. I have to use the override in the steering column to shift from park. Could these two be related?
Thanks in advance!
slick371 is offline   Reply With Quote
Old 07-11-2011, 11:19 AM   #8 (permalink)
Banned
View bob2's Photo Gallery
Thanks in advance!
if so it would seem that the problem with the light would occur alongside the stuck shifter, and not at other times?
bob2 is offline   Reply With Quote
Old 07-11-2011, 11:47 AM   #9 (permalink)
I have 3 issues:
1) will not shift from park unless I use the shift lock override
2) no brake lights (intermittent issue)
3) cruise control will not disengage when I press the brake pedal. I have to turn the cruise off and then apply brakes to slow down or stop. If I don't turn it off the cruise control will try to accelerate the car to maintain set speed when I apply the brakes.
I went thru my Haynes book and from what I can tell the brake switch is a part in all 3 systems (brakes, cruise control & shift lock). That's why I thought it may be the issue.
Old 07-11-2011, 01:55 PM   #10 (permalink)
Banned
I have 3 issues:
ok.... change it, then see what happens. 9.55 - 21.79 at rock auto
