Power Seat Motor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2011, 11:16 PM   #1 (permalink)
View DBGaither's Photo Gallery
Power Seat Motor
I have a '98 Avalon XLS /w bench seats, +200K miles. The drivers side seat will no longer recline or decline. Apparently the motor has died. At this time, my son is using the car for an out-of-town job and so I haven't had any time to investigate this myself and I only have access to the car on weekends.
So:
1) Are these motors still available or do I need to scrounge one from a junkyard?
2) Where exactly are they in the seat?
3) How difficult are they to replace?
4) Does anyone have any advice to give me before I undertake this?
-Doug
DBGaither is offline   Reply With Quote
Old 02-02-2011, 05:00 AM   #2 (permalink)
View Spankedmonkey's Photo Gallery
I'm partly in the same boat for my '96 XLS whereas my seat will only move forward and is stuck. The up,down, and recline work but no backwards.
Spankedmonkey is offline   Reply With Quote
Old 02-02-2011, 11:28 AM   #3 (permalink)
Blu08Taco's Avatar
View Blu08Taco's Photo Gallery
I'd check to make sure the tracks are properly lubed. Last time I looked, they use the same motor as the power windows, which after taking them apart, appear relatively indestructible.
Blu08Taco is offline   Reply With Quote
Old 02-02-2011, 01:33 PM   #4 (permalink)
Yeah, my seat has no problems moving forward or backwards on the tracks, it is only that the rake of the seat can no longer be adjusted.
Old 02-02-2011, 01:40 PM   #5 (permalink)
Avy
Gameroom cash: $821455
View pmesfun's Photo Gallery
I remember reading that the switch could be burnt out. I try to avoid using the motors in both seats because it sounds like their dying.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 02-02-2011, 05:32 PM   #6 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132150
View Jigg007's Photo Gallery
I would try bypassing the switch that drives the seat motor, and jump the motor to 12volts and see if it kicks.
If a motor works in one direction and not the other, then the switch is burnt out. I suffered similar problem in my car, passenger seat would only recline, and not come back up. So I'd get a friend that decides to go all the way down because its "cool"
Anyway, a temporary fix to a switch problem is disconnecting the faulty switch, jump 12volts to the desired motor. The seat should move, reverse polarity and it will move the other direction.
The switches are not sold alone, but the whole panel is sold as an assembly from Toyota, for somewhere around $200. However you can fix the switch yourself with a $5 DPDT switch from radio shack.
If the seat motors are identical to the window motors, then there should be a termoresistor inside said motor, which functions to limit current to the motor if it starts to heat up. If this resistor fails, then your motor will not work.
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
Old 03-01-2011, 03:14 PM   #7 (permalink)
That's a great idea, I'll try bypassing the switch to see what the problem is. Does anyone know how to access the motors? Are they under the seat? I cannot see and as I mentioned, I don't have a lot of time to experiment.
Anyone ever tear the seat apart?
Old 03-01-2011, 03:29 PM   #8 (permalink)
Okay, so I had the bright idea to widen my search to all Toyota passenger car forums and I found THIS LINK where the owner is fixing a problem with one of the motors in a Camry. This is helpful. I'll take pictures when I do mine and post them.
Old 03-05-2011, 12:05 PM   #9 (permalink)
Okay, so I took off the control panel and checked the switches. The switches were okay.
Old 03-05-2011, 12:06 PM   #10 (permalink)
So I then found the reclining motor and determined that the problem was the motor.
The Following User Says Thank You to DBGaither For This Useful Post:
Chunkywolf (03-05-2011)
Old 03-05-2011, 12:10 PM   #11 (permalink)
So I copied the numbers from the motor
TOYOTA
85820-41120
162000-5370
12V 12S
DENSO
And did some Googling. I found THIS LINK with the OEM replacement motors. Incredible!!! $369!!! Well, I guess I'll be headed off to the junkyard.
Old 03-05-2011, 12:27 PM   #12 (permalink)
Avarollin?
Jigg007's Avatar
Oh man, the 98s have memory seats? now THATS luxury!
Great job at continuing to post your results, very helpful for the future!
Old 03-05-2011, 12:46 PM   #13 (permalink)
Chunkywolf's Avatar
Gameroom cash: $144565
View Chunkywolf's Photo Gallery
Great... now I plan on even more junkyard shopping, gotta get me those programmable seats...
Black 95 Avalon XLS 170k
Spectra Blue 02 Celica GT(Rolling Chassis)
2009 Kenworth T-660 (Cat c-15) 447k
Chunkywolf is offline   Reply With Quote
Old 03-05-2011, 12:51 PM   #14 (permalink)
Avy
On the memory presets, idk if mine work correctly, don't use them at all. BTW The car has be ON or started in Park with your foot off the brake. Seems like there might be more wiring or switches needed than just swapping for the memory switches?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 03-05-2011, 12:57 PM   #15 (permalink)
Not sure if it makes any difference, but I do have a bench seat.
Tags
motor, seats
