So, after a few foggy mornings I decided it was time to install more lights on my car.
I removed my old junky drving lights, and replaced them with some new amber output fog beams.
Product link:
http://www.pilotautomotive.com/Produ...roductID=27129
But, the beautiful part was the mounting situation. While I orrignially was planning to remove the front bumper to do a nice job on the installation. (I also planned cutting into said bumper) I decided to take another look under the car.
what I found were some holes that were originally to attach the bumper cover too, but clips have been missing for quite some time. So I had an idea, to use that for mounting my lights. Turns out a 3/8th bolt fits nicely. Beginning with a light hammer tap to drive the bolt into the hole, then using a 9/16th (or 14mm) ratchet to poorly cut some threads into the aluminum(?) bumper.
Another crappy picture, and awful perspective:
I then removed the bolt, and applied some threadlocker to it so it would situate itself in the hole a little better. Thought about a lock washer, but shifted the bolt too low for my lights.
The only bummer using these holes was I had to cut into the rearside of the bumper to allow clearence for my choice of lamps. This was easily done with a knife heated by propane/mapp gas.
The fit turned out perfect, and I got pretty lucky with the clearence with the license plate.
