Gas light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2011, 07:26 PM   #1 (permalink)
View Sfgsr1's Photo Gallery
Gas light
I was just wondering how much gas I have left once the gas light comes on? Thanks
Sfgsr1 is offline   Reply With Quote
Old 03-01-2011, 07:50 PM   #2 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
In my experience(yes I have ran out of gas) its about 2.5-3 gallons.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 03-01-2011, 08:12 PM   #3 (permalink)
TN User
ThisBloodIsFake's Avatar
View ThisBloodIsFake's Photo Gallery
I remember reading somewhere it was 5 gallons. which makes sense because Avi's have 18.5 gallons and every time i've ever filled up when the light was on i only put in 13 gallons or so.
ThisBloodIsFake is offline   Reply With Quote
Old 03-01-2011, 08:17 PM   #4 (permalink)
Avy
^You're right, I was thinking when the needle was at the E line. The gas light on these cars are weird, mine comes on and off and back on when it gets low.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 03-01-2011, 08:25 PM   #5 (permalink)
TN User
haha i know right it always makes me laugh its the most indecisive idiot light i've ever seen
Old 03-01-2011, 09:24 PM   #6 (permalink)
CRESSIDA!!!
84Cressida's Avatar
Gameroom cash: $656020
View 84Cressida's Photo Gallery
It comes on and then goes off a few times to "warn" you, hence the name fuel level warning light.
I've never run out of gas, but I've been oh-so-close a few times with the light coming on numerous times and staying on with the needle right down to the E. I finally filled up and managed to shove in over 17 gallons and topped off without managing to overfill..so I was probably damn near close to bone dry .
1994 Toyota Pickup Xtra cab 4x2 22R-E 44,000 mi
1998 Toyota Avalon 1MZ-FE 137,000 mi
2005 Chevrolet Silverado Crew Cab 49,000 mi
2006 BMW 330i Sedan 85,000 mi
2007 Toyota Camry Hybrid 2AZ-FXE 62,000 mi
As of May 17, 2011. DEATH TO SCION!
84Cressida is online now   Reply With Quote
Old 03-01-2011, 10:16 PM   #7 (permalink)
Thanks for the quick replies now I know I won't run out going home tonight lol
Old 03-02-2011, 11:49 PM   #8 (permalink)
View skynet1988's Photo Gallery
I noticed that when that light turns on seems that it is a function of the float that is in the gas tank. Leading me to believe that the fuel reading is analog, not digital. If you come to a quick stop with the fuel light on it will turn off the light!
skynet1988 is offline   Reply With Quote
Old 03-03-2011, 08:32 AM   #9 (permalink)
TN User
Ya thats what we were saying i def. agree with that
My 1995 Toyota Avalon XL 175k
Neighbors 1991 Es 400
Old 03-03-2011, 02:23 PM   #10 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132150
View Jigg007's Photo Gallery
Most, if not all cars have a float in the gas tank, which infers that all the sensors are of analog nature. the signal may be converted to digital in new cars, but ultimately is still a wishy-washy(bum-pish) sensor. The meters improved in newer cars because the way the computer interprets the sensor like so:
Ignore moderate fluctuations in a short amount of time, Average your readings and then update the gas gauge every 60 seconds or so. Allow drastic change such as a fill up so the gauge responds much quicker.
The mighty Avalon only smooths out and delays the values, so the gauge is open for some interpretation while the vehicle is changing direction.
However the superior way to measure gas in the car would involve a flow gauge on the filler tube. Measure how much gas goes in, and how much gas leaves though the fuel pump. That would be nearly pin point accurate, unless you have a hole in the tank (man I'm on fire!(double pun combo!!))
The poor mans way is to always fill up your car, reset the trip, and take an average of your MPG. Then if you're in a pinch simply divide your trip by your average mpg, and voila, gallons remaining in tank.
That was probably waaayy more than you wanted to read, but knowledge is power!
I've ran out of gas on a highway once, and coasted all the way to a gas pump.. I only realized I was out of gas when I reached for the key! Thats a really good way to burn up your fuel pump too because its running with no gas around it which acts as a heat sink, and to mention its sucking air!!
You have about 4-5 gallons in the tank when the light begins to fade in and out, and you're down to about 3 gallons or less when the light is solid lit.
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
Old 03-03-2011, 03:26 PM   #11 (permalink)
CRESSIDA!!!
84Cressida's Avatar
I'm assuming our cars have a fuel shut off program or something that cuts fuel when you're about to run out of gas so the pump doesn't burn out, yes?
Old 03-03-2011, 04:27 PM   #12 (permalink)
Avarollin?
Jigg007's Avatar
It has either a pressure switch or a timer, probably both. I know when the car is initially turned from the OFF position to the RUN (not started) It turns on the fuel pump for three seconds, and shuts off. Once the engine is running I would imagine the pump begins to run continuously. This next part is speculation of course, but once the engine sputters and dies from lack of gas, the timing/ignition system should also shut down and also turn off the fuel pump, returning it just like the initial OFF->RUN state.
... maybe
Old 03-04-2011, 07:50 AM   #13 (permalink)
Chunkywolf's Avatar
Gameroom cash: $144565
View Chunkywolf's Photo Gallery
The fuel pump just runs to prime the fuel lines to 60PSI(most cars) when there are no injectors running. So, if the engine dies due to lack of fuel, The fuel pump will continue to pump until it reaches 60PSI(which it will probably never reach due to air getting in the line and such). I'm pretty sure fuel pressure is measured just above the pump, before the line exits the gas tank to head up to the engine compartment.
Black 95 Avalon XLS 170k
Spectra Blue 02 Celica GT(Rolling Chassis)
2009 Kenworth T-660 (Cat c-15) 447k
Chunkywolf is offline   Reply With Quote
