Your remote start is aftermarket. There is likely a setting that ables/disables your honk confimation.
The PRNDL, just like any other light, there is a bulb that probably needs to be replaced, not to big of a deal and....
The lamp light that comes on in the dash is usually because you have a bulb either burnt out or on the brink of burning out causing a difference in the wattage that is tripping the light. Just need a new bulb. You could have an incorrect bulb in there.
P.S. make sure that you get the Correct bulb or the light on the dash will not go away. Usually the brake like will trip this dash lamp. An easy way to confirm the brake is to turn on the car and step on the brake pedal, if the dash light comes on when you step on the brake, you have a burnt out brake light.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
