Well I sure hope you're ready for the weather thats coming our way
You mean the marker/parking lamps right? Because Im pretty sure our first-first generation (9597) do not have DRL modules.
If you got a spaaark, assuming you just shorted the -/+ wires together on the parking lamp. And that should 100% be fixed by a fuse like ChunkyWolf said. But say if you "injected" voltage into the system, like touched the parking light wire to 120V like someone i know (
) Then you have another problem.
You dont have a second battery in the trunk or anything? haha. Or maybe a capacitor or something silly. Next time around, make sure the parking lights are switched to off, and even remove the fuse or relay if you're paranoid. Or avoid the issue by not shorting the wires
You should have a voltmeter to check stuff out as you go.
