Rear brake corrosion? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2011, 08:27 AM   #1 (permalink)
View Plinker's Photo Gallery
Hello all!
I was hoping to receive some guidance regarding the rear disc brakes on my '99 Avalon XL.
When we bought the car 3 years ago, the rear rotors were severely corroded, so much so that they had to be trashed and replaced with new ones.
Even though the car is driven daily, the rear rotors continue to corrode badly, as if the rear calipers are not exerting enough pressure on the rotors to scrub off any rust. If I ever have to slam on the brakes, I can hear the pads rub on the rotors (loudly, sounds like someone is turning rotors in a shop).
So, there is some pressure getting back there, but I don't think it's enough. Is there some sort of proportioning valve on the 95-99 Avalon the may need adjusted? I can't find anything on it in the manual or on searching this site.
Is it possible with age of this car that it may just need a total rebuild (ie: rear brake hoses, calipers, rotors, and pads).
Thank you,
Denny
Plinker is offline   Reply With Quote
Old 04-07-2011, 02:16 PM   #2 (permalink)
View fourwheeler's Photo Gallery
Denny, I had a similar problem on my 98 where the caliper was only pushing on one of the pads. I diagnosed it as a corroded caliper slide pin/bolt. I removed the caliper slide pins, lubed them up thoroughly and the caliper was now able to slide and apply pressure to both sides of the rotor. It's a cheap fix and is something I would try before dumping money into a new caliper.
Good luck, fourwheeler.
fourwheeler is offline   Reply With Quote
Old 04-08-2011, 08:02 AM   #3 (permalink)
Thank you, I will try that sometime over the next couple of weekends and report back my results!
Denny
