Originally Posted by 95_Avalon
Hi,
Plan to do the coolant drain and refill for 95 Avalon. Few questions -
1. What's the proper procedure?
2. Where is the drain plug and where you fill in?
3. Does it use red (toyota long-life) coolant? How much will be needed for simple drain and refill?
Thanks in advance.
1. Not sure of a proper procedure... I'd assume it to be as simple as draining.. and filling
2. There should(haven't started on mine yet, but it's a non issue for me) be a drain plug on the bottom of the radiator, in the middle.
3. Yes, it does use toyota red coolant
I'm doing a radiator replacement on Tuesday, so this is what I know so far.
