Well, if the MAF is unplugged it is best to have it plugged in. But like most sensors on the car, a faulty sensor should not result in total failure. Instead, the ECU will assume the sensor is bad (not plugged in, no data), and use factory values to "limp' the car home/repair shop. It wouldnt start right up, but it should atleast try to turn over. MAF sensors become more important at higher RPMS.
When cranking, there is no sign of resistance? Does the exhaust smell rich doing so?
Keep in mind the three things you need for a running engine, fuel, air, and spark (well, compression too..)
Air is almost a no-brainer, and is usually never at fault. Unless you forgot to unwrap the air filter.
Spark can be tricky to observe. you need to use a spark tester (or mist some water onto the plug wires leaving the coil packs)
Fuel will be evident if you're able to smell gasoline in the exhaust after starting. Which wont be noticeable right away, but maybe after a minute or two. It will be very rich which also ties into spark. If you have the air, and the fuel, then obviously you have no ignition! However, if you smell no fuel then you may have a faulty fuel pump.
But if you can test you have spark, fuel, and air, then you might have to look at compression..
Good luck, besure to let us know if you fix it!
