Which Oxygen Sensor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2011, 11:19 AM   #1 (permalink)
View Timid Soul's Photo Gallery
(1995 Avalon)Code PO135 Bank 1, Sensor 1. Searching these forums I get different locations depending on the thread. Some say Bank 1 is the "Front" bank, in the front of the engine, which would be right there in front of me, easy to get to. Others say that it's on the back of the engine near the firewall. Sensor 2? Anyone know for sure?
Wonderful prizes and rewards for the correct answer! Come on! Register now, you could be a winner!!!! Sorry, .....this car is making me a bit
I'd appreciate the help, thanks.
Timid Soul is offline   Reply With Quote
Old 04-30-2011, 12:02 PM   #2 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
Bank 1 is the firewall side, Sensor 1 is after the exhaust manifold, above the steering rack.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
The Following User Says Thank You to pmesfun For This Useful Post:
Timid Soul (04-30-2011)
Old 04-30-2011, 04:11 PM   #3 (permalink)
Thanks. How many sensors are on the car? Also, a bit off subject, I just redid the valve cover gaskets and wonder if the oil leak that was there could have fouled the sensor. What do you think? Is a sensor repairable? Again, thanks for the answer.
Old 04-30-2011, 06:08 PM   #4 (permalink)
Banned
View bob2's Photo Gallery
doubt that it fouled the sensor but it could have fouled the plug. this is not as hard as it looks. unplug it. use contact cleaner to clean it. use sillyclone grease to coat it. plug it back in. disconnect the battery. hold your foot on the brake for one minute to reset the computer. reconnect the battery...
bob2 is offline   Reply With Quote
The Following User Says Thank You to bob2 For This Useful Post:
Old 05-02-2011, 10:54 AM   #5 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
If you used the wrong sealant on the VC gasket it could have killed the sensor. Must use product specifically labeled as "sensor safe", or Toyota spec'd p/n.
Unless seized, that sensor can be changed in 30 min or so. See my post from about 2 weeks ago for steps I used.
TedL is offline   Reply With Quote
Old 05-02-2011, 11:43 AM   #6 (permalink)
Where's your post on the sensor? Looks like it's gonna be hard to get to when I eyeball it. Thanks.
Old 05-02-2011, 12:43 PM   #7 (permalink)
Banned
interesting... how might gasket goop effect a sensor, encased in a cast iron pipe? are the vc gaskets not rubber? we don't use gasket goop on rubber gaskets... do we?
it's been quite a while since i turned wrenches... people are always changing things - it seems to make them feel important?
Old 05-02-2011, 01:26 PM   #8 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $353553
View BMR's Photo Gallery
Mostly no. But there's a few spots where it's supposed to get a dab of silicone sealant, like the "half moon" plugs. Maybe a couple other spots I forget.
BMR is offline   Reply With Quote
Old 05-02-2011, 04:18 PM   #9 (permalink)
Goop on the Gasket?
I did put some "goop" on the gaskets, very little, but I didn't take the guy seriously when he mentioned it. He certainly didn't know what I put on the car. No big deal. My concern was that possibly the oil leak had messed with or destroyed the sensor. Thanks y'all, I'll be checking it out.
Old 05-02-2011, 07:39 PM   #10 (permalink)
RTV is frequently used with gaskets in the "corners" where there's a sharp change in direction for a better seal.
As for how the vapors from sealant on the VC gasket get to the O2S or AFR sensor, there's this thing called the PCV system, introduced in the 1960's.
Old 05-02-2011, 09:33 PM   #11 (permalink)
Banned
ok... valves do have overlap... learned something today
Old 05-07-2011, 09:59 AM   #12 (permalink)
I've been trying to figure what this meant for days. I think you're attributing something to valve overlap (both intake and exhaust being open at the same time).
It's much simpler than that. The "air" between the valve cover (VC) and head gets moved into the intake charge through the PCV system. The intake charge burns and becomes the exhaust, which gets pushed out through the exhaust system, passing the AFR and O2 sensors on the way. Very simple, very direct, not passing through steel walls.
And if you use sealant on a VC gasket, the vapors from the sealant can become part of the "air" inside the VC.
Old 05-07-2011, 12:27 PM   #13 (permalink)
Banned
maybe - but i doubt it. i don't think whatever it is in the gases from the drying silicone can survive the compression and the fire.
i think, instead, that the valves in overlap allow the raw stuff to pass through the cylinders, into the exhaust. the pcv valve opens when there is no vacuum...
