Getting ready to do a big tune up! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2011, 10:54 PM   #1 (permalink)
View Fireshaker's Photo Gallery
Just bought a 96' Avalon. Engine has 243,000 on it. Valve covers are leaking like crazy, timing belt has never been replaced, and all the fluids are dirty.
I got the majority of the parts already. I will be tackling this project threw out the rest of the week.
List:
Valve cover gaskets
Timing Belt
Water Pump
Spark Plugs
Plenum gaskets
PCV valve
Power steering flush
Brake flush
Transmission drain and refill
Coolant Flush
Rear shocks
Air filter
Throttle body clean
Fuel Injector cleaning
I'll be taking pictures the whole way and doing a small write up in case anyone needs one.
Fireshaker is offline   Reply With Quote
Old 05-12-2011, 06:24 PM   #2 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
Nice, I did this back in December. btw the Power Steering system uses ATF Dexron III.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 05-12-2011, 07:51 PM   #3 (permalink)
View robcam13's Photo Gallery
dont forget the front diff. it needs some tlc as well
robcam13 is offline   Reply With Quote
Old 05-12-2011, 07:52 PM   #4 (permalink)
Avy
I thought the trans and diff share the fluid, no?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-12-2011, 07:53 PM   #5 (permalink)
no it has its own drain and fill plug. like a truck
Old 05-12-2011, 08:08 PM   #6 (permalink)
Avy
even on the 99? my instructor said its shared so did Tech1984 and many other members.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-12-2011, 10:15 PM   #7 (permalink)
Trans and diff do take the same fluid, just different sections of the transmission.
I use the power steering fluid Toyota supply's, not dextron.
Did I mention that I work at a Toyota?
89' Mark VII - 5.0L
96' Avalon LX - 3.0L
Old 05-12-2011, 10:51 PM   #8 (permalink)
Avy
Holy, so I have possibly 12 year old fluid in the diff.
I just read what was on the PS reservoir cap used that fluid.
Aha, so thats why, ZAK FI Cleaner is what came with the Toyota 30k service on the Sienna we were working on.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-13-2011, 05:33 AM   #9 (permalink)
Gameroom cash: $301225
View artbuc's Photo Gallery
Same fill point though, right? That is, when you fill the trans, fluid spills over into the differential.
artbuc is offline   Reply With Quote
Old 05-13-2011, 05:54 PM   #10 (permalink)
Have you ever wondered why you preform a drain and refill and the fluid is still dark?
Toyota's can use Dextron III, there are a few guys running it. How ever I'm gonna stick with the Zak fluids..
We use a lot of Zak products and I haven't been disappointed in one yet.
Yes sir! It took a little under 3.5 quarts for a drain and refill on my trans. I did it today, and man was it black.. Will be doing it again once a week for the next month or two.
89' Mark VII - 5.0L
Old 05-13-2011, 06:10 PM   #11 (permalink)
Avy
I dropped the past last week and it was cherry red, I done about 6 drain and refills in the past year.
Shifts just as smooth as the 07.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-13-2011, 06:30 PM   #12 (permalink)
Avy
btw are you doing the tensioner and pulleys?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-13-2011, 07:00 PM   #13 (permalink)
no the diff has its own drain and fill plugs.
Old 05-13-2011, 07:06 PM   #14 (permalink)
and like fireshaker i am also a toyota tech and have done many of these fluid changes.
i'm not totally sure why toyota used this setup but we are stuck with it.
Old 05-14-2011, 07:54 AM   #15 (permalink)
I'm talking front wheel drive where the differential has its own drain but does not have its own fill, at least that is the way my 99 Avy is.
