Cam position sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2011, 06:16 PM   #1 (permalink)
Gameroom cash: $301225
View artbuc's Photo Gallery
Cam position sensor
How many ohms should I see (99 avy, 3.0L V6). Thanks.
Mine is leaking oil and it looks like the gasket isn't sold separately. It is special - an O ring with an internal flat section to keep it centered on the sensor to ease installation. Think I'll just buy a nitrile O ring and position it on the head with a dab of grease. 20 cents for a new o ring is better than $100 for a new sensor. Maybe I will fortify the old O ring with some RTV and give that a whirl. Any other ideas will be appreciated.
artbuc is offline   Reply With Quote
Old 05-23-2011, 07:39 PM   #2 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
Cold Hot
DENSO Made: 835–1,400 1,060–1,6450
Wabash Made:1,690-2,560 2,145-3,010
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 05-23-2011, 07:44 PM   #3 (permalink)
Originally Posted by pmesfun View Post
Cold Hot
Thanks! I'm in the mid-range at 1.14 kohms on my Denso. Now to stop the oil leak. I just remembered that the cam position sensor started leaking oil when the car was about 6 months old and Toyota repaired under warranty. You can see how this is a chronic problem with oil sitting right on an O ring which deforms and gets brittle with heat/age.
Old 05-23-2011, 07:51 PM   #4 (permalink)
Avy
I would get a new o-ring. Don't use RTV, that just makes a mess. The o-ring should seal with no problems like it was designed to do.
99 Avalon XLS-149k
99 Lexus LS400-88k
