High idle when driving - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2011, 12:35 PM   #1 (permalink)
View bristol24's Photo Gallery
recently my 96 with 230000 mile has been idling high while driving, It will start off normal like around 800 rpm, but as drive for a few minutes and come to a stop it is running around 1700 to 2000 rpm. Any help would be greatly appreciated.
bristol24 is offline   Reply With Quote
Old 05-25-2011, 11:59 AM   #2 (permalink)
anyone?
Old 05-25-2011, 01:24 PM   #3 (permalink)
techtalk's Avatar
View techtalk's Photo Gallery
what kind of vehicle is this?
techtalk is offline   Reply With Quote
Old 05-25-2011, 01:28 PM   #4 (permalink)
techtalk's Avatar
the idle speed sensor might need to be replaced
Old 05-25-2011, 06:36 PM   #5 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
OP writes about a '96 and has posted in the year appropriate Avalon forum , so I'd proceed on the assumption it's a '96 Avalon................
TedL is offline   Reply With Quote
Old 05-26-2011, 05:43 AM   #6 (permalink)
its a 96 avalon. Has anyone had this problem before?
Old 05-26-2011, 05:56 AM   #7 (permalink)
could it be the idle air control valve?
Old 05-26-2011, 06:15 AM   #8 (permalink)
View fourwheeler's Photo Gallery
from what I've seen before on this forum, when the idle air control valve acts up, it usually causes a low RPM or poor idle, not a high RPM. Is there any codes? Can you have the OBD II scanned. Perhaps there is a code stored even though the CEL is not on. Autozone or other National parts chains will scan the car for free.
fourwheeler is offline   Reply With Quote
Old 05-26-2011, 06:22 AM   #9 (permalink)
any chance your throttle plate is dirty causing it to stick open causing a high idle?
Old 05-26-2011, 07:57 AM   #10 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
^ I was going to suggest cleaning the TB as a start. Might clear up the issue might not.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 05-26-2011, 12:27 PM   #11 (permalink)
no codes, I did have it scanned. I will try cleaning the the throttle body, It was just cleaned about a year ago.
Old 05-26-2011, 03:29 PM   #12 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
Make sure all vacuum hoses are plugged in as well.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 05-26-2011, 10:44 PM   #13 (permalink)
View robcam13's Photo Gallery
sounds like a pcv valve or vacume issue. when it acts up try spraying some brake cleaner at the vacume lines, pcv, tb, etc and listen for any rpm changes.
robcam13 is offline   Reply With Quote
Old 05-26-2011, 10:45 PM   #14 (permalink)
mass air sensor may also be dirty
Old 06-04-2011, 07:50 PM   #15 (permalink)
The trottle cable goes to a box near the battery, in the box the cable wraps around a half wheel, that wheel has a broken spring, anyone know what that part may be?
