97 avalon misfiring on two cylinders - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2011, 03:29 AM   #1 (permalink)
View obrienc's Photo Gallery
USA 97 avalon misfiring on two cylinders
Read the codes and drove it like 5 miles and it stopped any one have any idea what it could be.
obrienc is offline   Reply With Quote
Old 05-25-2011, 06:09 AM   #2 (permalink)
View fourwheeler's Photo Gallery
I thought each coil pack drove 2 cylinders. Any chance it is a bad coil pack?
fourwheeler is offline   Reply With Quote
Old 05-25-2011, 09:38 AM   #3 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
X2 on the coil pack problem. Sounds like one is starting to go.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 05-25-2011, 11:36 AM   #4 (permalink)
Gameroom cash: $301225
View artbuc's Photo Gallery
Which two cylinders are misfiring? Coil #1 fires Cyl 2 & 5, coil #2 fires cyl 4 & 1 and coil #3 fires cyl 6 &3. You do have the 3.0L V6, right?
artbuc is offline   Reply With Quote
Old 05-28-2011, 05:22 AM   #5 (permalink)
Yeah it was the 2 & 5 thanks for the help. Hasn't done it since then but I figured I would find out what it is so next time I know.
Old 05-28-2011, 11:43 AM   #6 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
I have 3 extra coils if you need them. I replaced them with new Toyota coils thinking they were causing my no-start problem but it was the crank gear/sprocket.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 05-28-2011, 12:10 PM   #7 (permalink)
What happened to your crank gear/sprocket? What was involved in getting it fixed? Thanks.
Old 05-28-2011, 12:36 PM   #8 (permalink)
Avy
Broken tooth, the crank sensor was losing it signal so it was starting at TDC over and over again. That was my teacher explaination. IIRC.
I made this thread in the camry forum, after numerous tests, replacing all coils, swapping plugs, igniter etc. Its all in that thread.
After doing all that, I gave up and had it towed to my Auto Tech class at school. My instructors tried everything, but nothing worked. So he had to call his former student who works at Toyota to come and check it. He had a genius way of checking the crank gear. He took out the crank sensor and with a flash light, looked in the hole turned while he turned the crank and that is how he found the missing tooth. After replacing it, the car started up like nothing ever happened. Of course all the fuel had to burn off for a while.
I got new NGK plugs as well b/c they were fouled out from all the starting.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-28-2011, 09:12 PM   #9 (permalink)
That is bizarre. Do you have any idea what broke the tooth?
Old 05-29-2011, 01:10 PM   #10 (permalink)
Avy
My friend and I were trying to get it off when we were replacing the oil seals. Lesson learned: Don't put a pry bar on the gear, its made out of weak metal. My teacher said the tooth probably got weakened and broke off after the couple weeks passed.
99 Avalon XLS-149k
99 Lexus LS400-88k
