Brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2011, 12:02 PM   #1 (permalink)
View turbofrank@verizon's Photo Gallery
Brakes
I was looking at pics of front and rear brakes and have questions.
Front /rear pads have shims installed into the pads. Do i need to install
extra shims. Most suppliers sell a shim kit.
On rear pads i notice 2 metal wire springs between the pads upper and lower. Do i need to install these?
98 Avalon
turbofrank@verizon is offline   Reply With Quote
Old 05-27-2011, 03:29 PM   #2 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
No you don't need extra shims.
I would install those springs onto the new pads.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 05-28-2011, 06:18 AM   #3 (permalink)
View fourwheeler's Photo Gallery
There are actually spring guide shims installed on all four calipers. The rear calipers should have four per caliper, and the front should have 2 per caliper. Just got done replacing 4 calipers.
fourwheeler is offline   Reply With Quote
Old 05-28-2011, 11:44 AM   #4 (permalink)
Avy
^What year avy do you have? Did you go with reman or new?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-28-2011, 12:34 PM   #5 (permalink)
I went with reman with the new mounting brackets and hardware and couldn't be more pleased. I have a 1998. I got the fronts locally, and went with Raybestos from Rock Auto for the rear. I also upgraded all 4 brake hoses as they were the originals and 14 years old.
Old 05-28-2011, 12:44 PM   #6 (permalink)
Avy
Awesome, I am going to do the same as well since mine don't bite at all. Also ABS comes on when its not supposed to, stopping power is the same whether I'm breaking normally or making a quick stop, etc.
So I'm not replacing the rear calipers or hoses. I am getting reman front Centric twin piston calipers(give more bite) and mounting brackets from the 95-97 avalon. As well as Centric rotors and Akebono Pro-Act/Toyota pads on all corners.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-28-2011, 01:32 PM   #7 (permalink)
cool, let me know how you like the centric rotors and akebono pads. I too am looking for something to give me a good bite, but budget friendly. I almost pulled the trigger on a set of Bendix either CT3 or the semi-metallic's.
