I did lower control arms/ball joints on my Camry a while back; pretty much the same setup. Yeah, the ball joints are a pain, because you're blocked from getting any kind of socket or box wrench on the castle nut attaching it to the knuckle. And an open end wrench spreads and slips off, rounding off the hex nut's corners. To get them off, I had to slit the nut on two sides using a dremel with a cutting disk, and then use a chisel to split it open.
