95 Avi oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2011, 01:31 AM   #1 (permalink)
View 50poundbrain's Photo Gallery
95 Avi oil leak
OK, I got the flashing O/D light under control and got it inspected. Now I'm turning my attention to the oil leaks. Both valve covers leak and one form the engine/trans seam. The flex plate isn't wet, so I don't think it's a rear main, but what does oil coming from a gap aft of the flex plate inspection window cast into the trans housing face?
50poundbrain is offline   Reply With Quote
Old 06-11-2011, 05:29 AM   #2 (permalink)
Gameroom cash: $301225
View artbuc's Photo Gallery
Before you start doing anything big, pull your PCV valve and make sure it is clean and working well. They need to be serviced on a pretty regular basis. When they clog, the crankcase pressurizes and pushes oil through the valve cover gaskets. I would never have believed that until I experienced it myself firsthand. Also, it you have the original PCV valve grommet, it is surely hard and cracked. You can get a new one at the parts store for $2. Removing the old grommet without allowing chunks to drop in is tricky but doable.
Do you have a cam position sensor on your engine? They are notorious oil leak points and easily fixed with a generic nitrile O ring.
artbuc is offline   Reply With Quote
The Following User Says Thank You to artbuc For This Useful Post:
50poundbrain (06-11-2011)
Old 06-11-2011, 06:27 AM   #3 (permalink)
WetOne's Avatar
Gameroom cash: $154300
View WetOne's Photo Gallery
even if chunks from the pcv grommet fall into valve cover there is a plate/baffle to keep the pieces from getting into the head
WetOne is offline   Reply With Quote
Old 06-11-2011, 11:11 PM   #4 (permalink)
I'll look at the PCV valve tomorrow. Thanks for that artbuc. I forgot to mention that mine is an XLS. What could be leaking at the engine/tranny joint besides a rear main? That's my worst leak.
