bigger oil filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2011, 08:45 PM   #1 (permalink)
Banned
View bob2's Photo Gallery
bigger oil filter
i don't think so. that stock oil filter is DINKY...
ah, but beware - the PH3600 is larger, yes, but it protrudes so far that the killer heat from the exhaust manifold will fry that darn thing, unless...
i used a pair of tin snips and a section of 4" furnace pipe, left over from installing a dryer outlet pipe. i just cut the pipe to wrap 1.5 times around the filter and to be .75 inch longer than the filter is tall.
i installed the filter, bent the pipe so it would be tight and slipped it onto the filter. bingo. no need for a clamp. instant heat shield!
no discernible difference, of course. but bound to be able to provide 4x the flow of oil, for those stoplight performances
bob2 is offline   Reply With Quote
Old 07-15-2011, 04:39 PM   #2 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
really?You're joking right?
A larger filter will simply contain more oil. The stock filter was DESIGNED specifically for your car. Why would you put a longer/taller/bigger filter there? There's not any benifit to it and like you've said, it's just closer to the manifold. Hotter oil Does not mean better performance.
Honestly, just a waste of time since the filter prices are the same and now you have something that's able to fall off the car when you're driving.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 07-15-2011, 04:57 PM   #3 (permalink)
Banned
if you're not smart enough to understand how a larger filter will pass more oil, well, you have my sympathy
Old 07-16-2011, 05:45 AM   #4 (permalink)
WetOne's Avatar
Gameroom cash: $154300
View WetOne's Photo Gallery
I have to partially agree with bob2 as I also run a larger than stock filter (same diameter,just longer). The same diameter is no closer to the header than stock so heat is not a problem. I change the oil every 10k while testing through Blackstone, so I see some benefit from the larger filter. Bob2, don't you think your heat shield may actually be transmitting more heat to the filter due to reduced clearance from the sheild? Guys it's not uncommon to run different than stock filter for a variety of reasons. For example I run a larger filter on my 4.0 tacoma because the oil capacity is 5.7 quarts with stock filter 6.0 with the one I use and for the reasons stated above.
WetOne is offline   Reply With Quote
Old 07-16-2011, 07:06 AM   #5 (permalink)
Banned
hey wetone
no, i don't think the heat shield transmits more heat. it intervenes in the flow of radiated heat - absorbing the heat that would hit the oil filter, then providing an interim cooling barrier. radiant heat is the thing, here. the piece of metal fits quite loosely, transferring little of the heat it receives. it cools in the airflow, instead
Old 07-22-2011, 07:13 AM   #6 (permalink)
View Slater8756's Photo Gallery
I was assumed that a big filter should be just necessary which contains high quality range for oil filtering to remove contaminates from engine oil.
used auto parts
Slater8756 is offline   Reply With Quote
Old 07-30-2011, 02:08 AM   #7 (permalink)
View American Pie's Photo Gallery
I just changed my oil today and switched to the longer size WIX filter. No problem with it except one minor irritation: the end cap is ever-so-slightly smaller in diameter than the stock size filter, which means that now I have to run out and get yet another oil filter wrench. I think I must have about ten of them that I've collected over the years; so many cars I've owned have utilized filters that require a unique wrench. Why can't there just be a few different, industry-standard sizes?
If anybody knows of an adjustable oil filter wrench that actually works well, let me know where you got it.
American Pie is offline   Reply With Quote
Old 07-30-2011, 07:03 AM   #8 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $913527
iTrader Score: 59 reviews
[quote=American Pie;3624217]I just changed my oil today and switched to the longer size WIX filter. No problem with it except one minor irritation: the end cap is ever-so-slightly smaller in diameter than the stock size filter, which means that now I have to run out and get yet another oil filter wrench. I think I must have about ten of them that I've collected over the years; so many cars I've owned have utilized filters that require a unique wrench. Why can't there just be a few different, industry-standard sizes?
My Mechanic uses one like this.
Amazon Amazon
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
