first post and question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-14-2011, 03:42 AM   #1 (permalink)
View avalon guy mac's Photo Gallery
Gen1 first post and question
I have a 1997 avalon xls and i was told that if i wanted to make it fast i could order aftermarket items but under a camry and it would fit, because i cant fine anything strictly for an avalon. so my question is will it work?
avalon guy mac is offline   Reply With Quote
Old 07-14-2011, 05:18 AM   #2 (permalink)
Gameroom cash: $254367
View sarsman45's Photo Gallery
Hi and wecome to TN!
It depends on what you want to do. As a previous Avalon owner, its a fast car to begin with ,especially if you keep ECT on. Given the fact that your engine is a 1MZ-FE, you can start there and see what fits into the car.
Remember, preventative maintenance and a few other small changes to the engine while keeping it stock will increase performance.
I'll add more tm, but ask away with what you want to do and I'll try to help you on your way!
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
sarsman45 is offline   Reply With Quote
Old 07-14-2011, 08:02 AM   #3 (permalink)
Thanks
Thanks for the reply. I love the fact that it is a fast car naturally but i wanted to do a intake, exhaust, and i dont know what else i could do with out dropping alot of money.
Old 07-14-2011, 08:53 AM   #4 (permalink)
Banned
View bob2's Photo Gallery
i have a almost stock 97 that runs right. there certainly is no point to adding high performance equipment, as the car can not deal with the power the engine makes right now. there is no posi, or hope for installing a posi... and w/front wheel drive posi would be very dangerous on slick roads.
the wheels just spin. it can not put the power it makes now on the ground. so, why bother? you will receive nothing for your efforts... not to mention screwing up a really nice car, just the way it is.
bob2 is offline   Reply With Quote
Old 07-14-2011, 10:57 AM   #5 (permalink)
so its really not worth it to do anything to my avalon and just leave the engine be
Old 07-14-2011, 02:36 PM   #6 (permalink)
Banned
an aftermarket air cleaner improves engine output more than you would believe...
i used bosh irridium plugs. many say not to use bosh but the irridium worked great! running some lucas through the gas then changing the fuel filter works wonders, as well.
my favorite mod is Greased Lightning teflon treatment. it will really slick things up. you will notice a difference within a few minutes BUT i would not use this product more than every 6,000 miles, as teflon builds up in the rings and causes the engine to begin to use oil, if overdone. get some at o'riley auto parts.
if your avvy runs right more power will not be something you will need
Old 07-14-2011, 02:43 PM   #7 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
i feel that when people start throwing the word "fast" around in this forum it means "fast for a toyota".
seriously, what toyota (stock) is fast? i guess it depends on your definition of fast. i'm sure there is someone that thinks my wife's solara is fast.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 07-14-2011, 02:56 PM   #8 (permalink)
Things to do that are cheap and would help out in the long run (more like maintenance but gives a little more power/comfort to your vehicle)
Go Synthetic - better fuel mileage and better performance on the engine (dont do it if the car has been on conventional oil for its life. The engine is known to have sludge issues that come back to bite you if you aren't ready for a expensive gasket/seal replacements because synthetic is thinner and may come out of the seals that have been worn down. Try a blend and see how well it runs first if you dont know. Don't forget to replace the oil filter!
New Engine Filter - Car needs to breathe right? A new/clean filter would allow more airflow into the engine, increasing performance.
Clean the Throttle Body Intake - A cheap fix that can do wonders to performance and gas consumption (very slight but makes the car perform better). Cleaning the body of the carbon deposits also increases airflow. Will help rough idling and may lower normal idling.
Drain and Refill Tranny Fluid - will allow the car to shift more smoothly, leading to more comfortable ride.
Spark Plugs
Wash and Wax
Now, onto the intake exhaust question you asked:
Given the fact that intake/exhaust kits are relatively inexpensive (give or take), they rob the car of its gas, making a 15-20mpg car into a 12-16mpg car. Also, It would become louder.
The 1MZ-FE does well if you wanted to attach a cold air intake to it, but dropping a KN filter also does the trick if you are short on cash.
The exhaust kits (usually mufflers) usually do nothing in performance (usually increase gas consumption) but instead make loud noises. What you need are replacement exhaust headers paired with good mufflers that will give you the umph you need for what you are trying to do. BEWARE OF DROANING if you go this route, because piping is also important when working on the exhaust. From my experience, stock piping is usually best. A good muffler shop that does custom work may be better off in helping you for this.
A CAI can run you up to $200 and an exhaust kit (muffler set) can run up to $400 (dont get ripped off, just buy a muffler if you want some noise) and headers up to $400.
The Following User Says Thank You to sarsman45 For This Useful Post:
avalon guy mac (07-15-2011)
Old 07-14-2011, 09:31 PM   #9 (permalink)
Banned
your wife's solara will sho nuff outrun that muskrat on the highway... and so will my avalon. a drag race would belong to you, naturally, as you have rear wheel drive and about twice the displacement.
yes, fast is a perception, just like everything else. my perception of fast has changed since i drove a 67 charger with a 671 protruding from the hood. i don't miss 8 miles/gallon... imagine that today! WOAH!
i suppose fast is relative... to the cars around you. by that standard my avvy is fast, indeed
Last edited by HATEnFATE; 07-18-2011 at 10:58 AM. Reason: unneccesary comments not pertaining to thread
Old 07-14-2011, 11:34 PM   #10 (permalink)
CTB727's Avatar
Gameroom cash: $587535
View CTB727's Photo Gallery
I have heard a custom Y-pipe is a good bang for the buck mod for these cars, along with a less restrictive cat converter. Though I'm not entirely certain, so don't quote me
There are a few members here I believe, with intakes. One of which has a vid on youtube. Sounds pretty nice.
1999 Toyota Avalon XLS
2006 Toyota Tundra Double Cab X-SP
2010 Lexus ES350 w/ Nav package
Originally Posted by rty View Post
Six Camrys, one from each generation. In a temperature controlled alarm secured garage filled with Camry memorabilia. I just worry I might not be able to enjoy every Camry. So many Camrys so little time.
CTB727 is online now   Reply With Quote
Old 07-15-2011, 12:53 AM   #11 (permalink)
i agree that fast is a preception but went my avalon takes off next to a civic with some work done i win but comparing a mustang to a avalon is changing car class all together. its comparing apples to oranges and of course a mustang is going to win because it was built to move fast with quick acceleration and has a bigger block and performance parts. if your going to compare cars you have to keep in the same class
Old 07-15-2011, 06:32 AM   #12 (permalink)
Banned
OMG!!!
if you're not getting codes ****DO NOT**** mess with the cat!
you'll open up a can of worms you may never solve!
Old 07-15-2011, 10:48 AM   #13 (permalink)
CTB727's Avatar
Originally Posted by bob2 View Post
OMG!!!
Alright, good point.
OP, avoid touching the cat.
Old 07-15-2011, 01:21 PM   #14 (permalink)
lol, you have got to be kidding me! sadly, i don't think that you are.
man, i should have known that my wife's solar could smoke my gt500. what an idiot i am for thinking her car is slow.
Old 07-15-2011, 01:22 PM   #15 (permalink)
of course it's in a different class and the comparison is ridiculous. my daily drive is an impreza wrx and it will hold its own against any toyota and is turbo from the factory.
but i keep the impreza stock and i drive it daily, because to me it's not worth tuning. it's fun to zip around town in though.
but i agree with you that fast is relative and it all depends on what you are comparing to.
Tags
avalon, exhaust, intake, parts
