This sure sounds like fuel pump. Pop the back seat bottom up and there you'll find the cover to the pump. The rest is cake.
Line wrenches are needed to remove the fuel line. Careful, under pressure!!
The pigtail harness in the pump bracket needs a close inspection also to determine high resistance from poor contact.
On older models like yours, I like to replace everything in there. Do it once, do it right.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
