98 avalon code p0446 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2011, 06:56 PM   #1 (permalink)
View turbofrank@verizon's Photo Gallery
Code has set about once a week for 6 months. After much reading and searching i may have solved problem. replaced gas cap that didn't work. On my Avalon the evap cannister is in eng compartment contrary to all info pointing to gas tank area. After jacking car i discovered its not there. I tested the VSV switch with a 9volt battery it should click. Old switch was replaced with working switch. Next week i will let you know outcome.
turbofrank@verizon is offline   Reply With Quote
Old 08-17-2011, 07:20 PM   #2 (permalink)
Since last post no more light and even passed Va roller emission test.
Old 09-02-2011, 07:20 PM   #3 (permalink)
View skynet1988's Photo Gallery
I had this problem holding up my Illinois emission test along with a problem with a shift solenoid.
Glad it worked for you!
skynet1988 is offline   Reply With Quote
