Originally Posted by drh
Thanks for responding BonzoGonzo.
Fan 1 relay checks out ok. I pulled the connector for that fan and hooked up my voltmeter, its getting 12V. But whats weird is that its getting 12V even with the A/C off. Maybe because its so hot (outside temp) it goes ahead and tries to kick it on anyway? Either way it looks like the fan motor is dead.
You've got me scared to see how much these fans cost now.
yeah. your voltmeter is a very high impedance device. use a test light. it will draw a little current and make those "ghosts" disappear...
the amount you'll find for those fans is outrageous. try 1-800-radiator... they are the suppliers to autozone, etc, and they will sell direct for the same prices. they sell chinese cr*p, but it works... when i heard almost $200 for a !@#$%^&*()!! FAN, i 'bout coraked! and it would have been the same thing, just marked up about 125%...
you might swap connectors, as he said, but i think they're on opposite sides of the radiator and getting the wires loose so you could make it to the plug on the other side would be nasty... but you might remove the fan that's dead, and do it that way?
