Wheel lug nuts thread - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2011, 09:18 PM   #1 (permalink)
View namiam's Photo Gallery
I was replacing a tire, and realized that one of the lugs (front passenger) will not tighten. It seems the threads are crushed, so the nut just goes around and around and will not tighten. This really frustrated me for about an hour!
I am thinking that the threads on the mating part of the lug nut is ruined, so is there a part name I can look for to fix this?
Wheel will come off (AGAIN!) if I drive. Thankfully, I was driving slow when this happened.
namiam is offline   Reply With Quote
Old 08-24-2011, 09:51 PM   #2 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
You will need a new lug nut and lug stud. You have to remove the caliper and rotor and tap out the damaged lug stud from the axle hub. There is a slot where the lug stud can slide out. You can find these parts at you're local auto parts store.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 08-24-2011, 10:16 PM   #3 (permalink)
Dave's
Gameroom cash: $123850
View Dave's's Photo Gallery
When re-installing, I just push the stud in place and then tighten. When torqued properly the stud should be fully seated correctly. You should not have to 'beat' it back in place.
Dave's is offline   Reply With Quote
Old 08-24-2011, 10:45 PM   #4 (permalink)
Yeah I torqued it properly.. but don't understand how this could happen anyways.
Old 08-24-2011, 10:46 PM   #5 (permalink)
Avy
This happens often when the bolt is cross threaded or over tightened.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 08-24-2011, 10:48 PM   #6 (permalink)
D*mn NTB!!!! This gives me another reason why I should have all services done at Toyota !
Old 08-24-2011, 10:52 PM   #7 (permalink)
Avy
Haha, not as bad as Discount Tire that cross thread FOUR lug nuts on ONE wheel on our van. I had to replace all of them. I would find an independent mechanic that specializes in Toyotas. I did and he is awesome, he was a former ASE Master Tech at Lexus. He invites me into the shop and we discuss what is being fixed on my car and other cars in the shop. Really cool guy, and his prices are very reasonable.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 08-24-2011, 11:07 PM   #8 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260740
View Yuko's Photo Gallery
It’s one reason why we try to do as much of the services and repairs ourselves. I would change my own tires if I have both mounting and balancing machine in my little garage. I can't count how many times Firestone lost the hub centric rings on my alloys. As for Sears, they once stacked so much "stick-on" weight on the inside of the wheel that it jammed into the front brake caliper.
Also, many times the lugs can be over-torque because of anti-seize on the studs. Sam's Club did that once when it's highly recommend that the studs be clean and dry when installing the lug nuts to prevent false torque reading.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 08-25-2011, 09:27 AM   #9 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $353553
View BMR's Photo Gallery
Your mention of Sears reminds me of this Ron White schtick. He cracks me up. Rated R for language.
I've lost count of how many lug bolts/nuts I've had to replace after the Bozos at the local tire shop get done using their air wrenches on 'em.
BMR is offline   Reply With Quote
Old 08-26-2011, 12:07 PM   #10 (permalink)
View turbofrank@verizon's Photo Gallery
remember we all have to start inexperienced somewhere please not on my vehicles.
turbofrank@verizon is offline   Reply With Quote
Old 08-26-2011, 12:09 PM   #11 (permalink)
Haha thanks guys
Old 08-26-2011, 11:01 PM   #12 (permalink)
This was an easy repair. However, I could not seat the stud properly... there is still about less than a 1/4 inch left but could not get the thing in.
Old 08-27-2011, 06:36 PM   #13 (permalink)
It should seat properly try buying a stud somewhere else. Hope stud hole was cleaned out first.
Old 08-29-2011, 09:28 PM   #14 (permalink)
I got my stud at Autozone... I tried to bang the stud in with a hammer, but this did not work. I tried to tighten the stud by torque'ing a nut, and the stud kept spinning as I tried tried to torque it. Am I doing something wrong? Are these studs not supposed to go in all the way???
I did drive with them today (55 mph max) and didn't notice anything out of the ordinary, but I don't feel safe at all!
Old 08-29-2011, 09:42 PM   #15 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $616031
View Zembonez's Photo Gallery
You have no way to blame this on NTB. This could be the result of most anybody's screwup on a 12 plus year old car. The stud might have been overtightened long ago and finally just let go.
Zembonez is offline   Reply With Quote
