Originally Posted by 71GTJ
Hey BonzoGonzo, I've edited my previous question. No requirements. I wish i had a thousand!!!!
my car goes ito reverse at 1000 rpm or better, every day when she is cold...
how does your trans fluid look? is it burnt (black) with gritty looking stuff in it? often times old, worn-out fluid will cause rough shifting, of all kinds...
changing the trand fluid is a PITA... can't do it all at once. first unbolt the pan, clean it inside, install new filter (being CAREFUL not to over-tighten the bolts for the filter, as they also hold the valve body on) and replace the pan.
now you can start draining 2 quarts of fluid every time you change your oil, via the drain plug in the bottom of the tranny pan. it will take quite a while for this to replace the fluid. pep boys will power flush it for about $150...
