My Steering Wheel rattle fix - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2011, 12:18 PM   #1 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
For the past 6 months I would get an occasional rattle from around the steering wheel/air bag rattle. It would drive me insane. Lately the rattle has happened more frequently so I took advantage of today's weather to fix it.
I could reproduce the rattle if I hit the steering wheel around 300 degrees, right around where the airbag connects with the wheel on the right lower side. When I would hit that area, the rattle would make the noise on the other side, on the cover behind the steering. If I pulled the cover closer to me(no play) there was no noise. So now that I found it, I took the wheel and air bag and everything else off and applied dynamat extreme to the contact points on both sides to be safe.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
The Following User Says Thank You to pmesfun For This Useful Post:
TrailDust (09-05-2011)
Old 09-05-2011, 07:52 PM   #2 (permalink)
Banned
View BonzoGonzo's Photo Gallery
how do you disable the airbag?
BonzoGonzo is offline   Reply With Quote
Old 09-05-2011, 10:56 PM   #3 (permalink)
Avy
Disconnect the battery and wait 90 seconds. I waited 5 minutes to be safe.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 09-06-2011, 08:38 AM   #4 (permalink)
Banned
yeah - that is scary. i've heard of people actually betting killed by tools they were holding when the airbag went off! you might step on the brake, after battery disconnect, just to make sure...
thanks
Old 09-06-2011, 01:49 PM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $353553
View BMR's Photo Gallery
Nice DIY pmesfun.
Maybe I'm being thick-headed, but it's not totally clear to me what was rattling. Was it the plastic cover behind the steering wheel buzzing against the wheel's spokes?
BMR is offline   Reply With Quote
Old 09-06-2011, 02:48 PM   #6 (permalink)
Avy
Originally Posted by BMR View Post
Nice DIY pmesfun.
Thanks,
Yes, the left side of the cover was. Sounded like when you close the rear doors with the windows down, and you get that sound, but very rapid. The tires on the car not the best, so on rough road surfaces, I can feel vibrations through the wheel. This plastic cover,
would rattle against the right metal piece where I put the dynamat. I also put strips of dynamat on the cover so the noise will never come back. So far, my commute to school has some rough roads, no rattles. I'm a happy camper.
The only other noise in the interior is when I'm driving solo, the passenger seat, the top part, will shake(front/back, very fast) pretty odd. I'm not sure how to fix that one. Maybe lube some part under the seat, replace a spring? It doesn't make noise with a passenger. I'll see if adjusting the seat position(i.e. reclining the top part of the seat back, or something) helps.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 09-06-2011, 10:35 PM   #7 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Cool, thx. My Avy has a rattle/buzz that's hard to tell where it's coming from; somewhere from the front left dash area, sounds like. I'll check this out.
