Windshield Washer Puzzler - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2011, 08:23 PM   #1 (permalink)
View ottogaus's Photo Gallery
Discovered the tubing attached to the windshield washer fluid reservoir was no longer attached so reattached it. Used the windshield washer which caused the tubing to again become unattached (and drain the washer fluid - arrrgh!!). Reattached the tubing again, this time using a hose clamp to make sure it didn't pop off. Washer fluid now leaks from the underbelly of the car after every time I use the washer. Blew air through hoses to try to clear any blockage, but still have same problem. Nozzles are not clogged because they work properly (before washer fluid reservoir drains due to leak). Help - I'm stumped!
ottogaus is offline   Reply With Quote
Old 09-18-2011, 10:33 PM   #2 (permalink)
Banned
View BonzoGonzo's Photo Gallery
replace hoses - they leak
BonzoGonzo is offline   Reply With Quote
Old 09-19-2011, 06:25 AM   #3 (permalink)
View fourwheeler's Photo Gallery
Just so I'm clear, you blew air through the hose that attaches to the washer reservoir and the air blew through the lines fine, so the lines are not blocked?
fourwheeler is offline   Reply With Quote
Old 09-19-2011, 07:25 AM   #4 (permalink)
Yes, blew air (via a can of canned air for dusting electronics) from the ends of the hoses attached to the connection on the side of the hood - one hose leads to the reservoir and the other to the nozzles. Also blew air into each of the two nozzles. Only experience the problem (washer fluid dripping from the underbelly) after using washer. I am thinking I may still have a blockage and possibly also a leaky hose. Thoughts??
Old 09-19-2011, 10:07 AM   #5 (permalink)
View chuckoff's Photo Gallery
May be leaking at grommet that seals pump to resivore, or line from pump.
chuckoff is offline   Reply With Quote
Old 09-20-2011, 10:25 AM   #6 (permalink)
I don't think your canned air is providing enough volume to tell if you have a blockage at the nozzle or not. The air is probably just blowing out of the open tube. Try getting access to a blow nozzle from an air compressor and create a seal with your tubing and blow towards the nozzle. It would indicate if air is blowing from your washer nozzles they are clear or not, or blow some junk out.
Old 09-20-2011, 05:55 PM   #7 (permalink)
Banned
straight pressure from an air compressor will, of course, blow the vacuum lines used for the washer fluid apart...
Old 09-22-2011, 12:14 PM   #8 (permalink)
try turning down the pressure
Old 10-06-2011, 10:52 PM   #9 (permalink)
Skully4's Avatar
View Skully4's Photo Gallery
how do you gain access to the bottom of washer ? is there access behind tire?
Skully4 is offline   Reply With Quote
Old 10-06-2011, 11:26 PM   #10 (permalink)
Banned
remove the plastic panel on the bottom of the fender
The Following User Says Thank You to BonzoGonzo For This Useful Post:
Skully4 (10-07-2011)
Old 10-06-2011, 11:51 PM   #11 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
+1, I replaced mine 2 weeks ago, really simple. 2 bolts and 1 nut hold the tank.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
The Following User Says Thank You to pmesfun For This Useful Post:
Old 10-07-2011, 07:45 AM   #12 (permalink)
I disconnected the two hoses where they attach via a connector on the pass side of the hood. Took a small can of dust-off canned air (don't have a compressor) and blew into both hoses. Problem solved. Thanks for everyone's help.
