1997 Avalon Oxygen Sensors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2011, 12:57 PM   #1 (permalink)
View rbcole123's Photo Gallery
Mechanic wants $800 to replace all 3 oxygen sensors (2 front, one rear) on my 1997 Avalon, consisting of $239 for each front sensor and $199 for rear, with $100 labor. Check engine code indicates this is the issue. Sounds expensive to me -- is this a fair price?
Alternatively, is this a repair I can do myself? Doesn't sound difficult. What exact parts would I need from, for example, ?
Thanks.
rbcole123 is offline   Reply With Quote
Old 10-06-2011, 01:02 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $353553
View BMR's Photo Gallery
Seems highly unlikely all three would go bad at once. Did he say what the error code was?... should be something like Pnnnn, where the n's are numbers.
Edit: If it's the just the one in the front bank, it's about as easy to replace as it possibly gets. The rear bank is harder, but not ridiculous. The third one, downstream from the cat is the most difficult. I've never done it, but if I recall correctly, the driver's seat has to come out and access it from the interior. They have threads that screw in to the exhaust, so they can be stuck hard sometimes.
BMR is offline   Reply With Quote
Old 10-06-2011, 01:54 PM   #3 (permalink)
This is the code: P0136 (Bank 1 Sensor 2).
Old 10-06-2011, 03:51 PM   #4 (permalink)
Banned
View BonzoGonzo's Photo Gallery
sensor 2 is the rear. the seat comes out easily. google o2 sensors. they can be had for considerably less...
BonzoGonzo is offline   Reply With Quote
Old 10-06-2011, 04:20 PM   #5 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
Just be sure to get Denso sensors, either through an online dealer like TN member Toyopartsman, or by looking up the Denso part # and searching for a supplier. Denso is the OE manufacturer.
TedL is offline   Reply With Quote
Old 10-06-2011, 05:34 PM   #6 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
Amazon has them cheap,
Amazon Amazon
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 10-07-2011, 05:06 AM   #7 (permalink)
Gameroom cash: $301225
View artbuc's Photo Gallery
Listen to TedL - do NOT use anything except Denso, especially don't use Bosch. Also, don't replace the fronts until you need to.
artbuc is offline   Reply With Quote
Old 10-08-2011, 03:38 PM   #8 (permalink)
How to install O2 sensor
I now know that I need to get the rear 02 sensor in my 97 Avalon. The code was P0136 (Bank 1, Sensor 2). I'm confused as to how this is installed -- does the driver's seat come out to access the sensor, and is it hard to remove? If too difficult I will bring to a mechanic, but I'd like to do this myself as it seems like an easy job.
Thanks as always.
Old 10-08-2011, 06:24 PM   #9 (permalink)
Banned
passenger's seat, 'cause toyota was too STUPID to make a hole in the floor, large enough to pass the plug for the sensor.
alternatively, the hole can be cut, the metal bent down, the plug moved out and changed, then the metal bent back into place and, finally, use silicon sealer to make the mess waterproof...
Old 10-09-2011, 02:22 PM   #10 (permalink)
Reality check time. The passenger's seat is retained by four bolts, each of which takes less than a minute with a hand ratchet...never mind pneumatic. Just put seat all the way back to access front bolts, and vice versa. Then tilt seat rearward to rest on rear seat.
You do not want to drag out the saw or torch to avoid R&R'ing four bolts with unfettered access.
Old 10-09-2011, 05:10 PM   #11 (permalink)
Banned
i even said the seat comes out easy. but there's a little more to it. seat needs to come all the way out. opportunity to lube the power seat, there. shifter cover needs to be pried off. i lunched a speed nut and that was a trip to the junkyard... carpet, and hanging it back onto the rails for the console takes time.
i just used tin snips the first time. took 2 minutes, then 2 more to button it back up. o and the front outside bolt is kind of a pain to put back. start it by hand. the ratchet will cause it to try to go in crooked... plastic covers r fun, 2. specially the inside rears
doing it all from under the car in about a half hour... well, there IS something to be said for that.
Old 10-09-2011, 05:16 PM   #12 (permalink)
Avy
I loathe the day I have to do this, so the passenger seat, carpet and center console has to come out?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 10-09-2011, 06:05 PM   #13 (permalink)
No. Remove seat. Then you reach in under the carpet to unplug the sensor from the wiring harness. Console doesn't need to be touched. The snap on/snap off door sill trim needs to be pulled up to allow reaching under carpet. Throw front floor mat on driveway and kneel on it to reach in from side. Look under car to see location where O2S wire comes up through floor, reach there and follow wire with hand. Simple. Very simple.
The Following User Says Thank You to TedL For This Useful Post:
pmesfun (10-09-2011)
Old 10-09-2011, 06:08 PM   #14 (permalink)
Avy
Wow, that's cake. Good time to look into why the top part of the seat shakes back and forth when nobody is in it.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 10-10-2011, 01:38 PM   #15 (permalink)
Thanks, doesn't seem too hard. To unscrew the old sensor and install new one though, you need to put the car on a lift?
