98 Rack & Pinion Bolts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2011, 06:03 AM   #1 (permalink)
View dublin8300's Photo Gallery
I am trying to replace rack and pinion. Everything is disconnected, but I have to get the bolts out. I am using a 19mm wrenc h, on the nut side(closest to engine), but cant get it to budge. The head of the bolt (towards rearof car) is blockedd bythesway bar. Should I remove the sway bar to loosen the bolts from the head side?
There are a ton of post on here about replacing, so I figured someone would know!
Thank you in advance!
dublin8300 is offline   Reply With Quote
Old 10-21-2011, 09:02 AM   #2 (permalink)
Banned
View BonzoGonzo's Photo Gallery
try a torch with "map" gas - that's propane + oxygen.
you should be able to pry the sway bar back enough to get a wrench in there...
BonzoGonzo is offline   Reply With Quote
Old 10-21-2011, 03:55 PM   #3 (permalink)
I wrench, therefore I am!
Gameroom cash: $214400
View TedL's Photo Gallery
As a new member of TN, I remind you that as with almost everything online, some info and suggestions are best ignored. Use common sense.
TedL is offline   Reply With Quote
Old 10-21-2011, 04:28 PM   #4 (permalink)
Gameroom cash: $130400
View MatrixPC's Photo Gallery
If this is the solution , take it to the mechanic.
2012 Camry Hybrid XLE Cosmic Gray/Ivory
2011 Sienna XLE Super White
89 Supra Turbo HID Conversion
89 Supra Turbo LED Conversion
89 Supra Turbo CarPC
2004 Matrix XR CarPC A moron in a Civic Hit n Run. Total loss.
MatrixPC is offline   Reply With Quote
Old 10-21-2011, 07:19 PM   #5 (permalink)
Banned
i am a mechanic.
take it to a technician. he'll charge you for disassembling the entire car... rofl. or, do it yourself. those nuts that hold the sway bar on are FUN! then you still have the problem of the stuck bolts... not sure how a technician would handle bolts that are stuck, after 14 years or so... prombly remove the engine/trans, so he/she could gain direct access to them!
it will be only after you're done that you can say just who it is that needs to be ignored .)
Old 10-21-2011, 07:48 PM   #6 (permalink)
I did the R&P on my son's 97 Camry back about 6 years ago, and don't remember this being a big problem. Do you have ratcheting box wrenches, like gear wrench? FSM procedure for R&R the R&P says to free the sway bar for movement by removing the two bushing retainers (4 bolts, again best dealt with using ratcheting boxes). Change bushings while you're in there.
Old 10-22-2011, 07:53 AM   #7 (permalink)
Banned
another ally mechanic trick is to put the box end of another large wrench into the open end of the wrench that's on the bolt, so that it can be used as an extender... increasing the leverage (doubling it) and probably getting the thing to pop.
Old 10-22-2011, 08:39 AM   #8 (permalink)
For "no slip" leverage, I recommend getting the plumbing dept at HD/Lowes to cut a 10 ft length of 1.25 or 1.5 (preferable) inch steel pipe into a 4, 3, 2 and 1 ft length, and thread both ends. Buy one coupling also. Cheap way to get reliable leverage that can slide over a ratchet or combination wrench. Just don't use the long ones with ratchets you'd have to pay to replace.
Old 10-22-2011, 11:03 AM   #9 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
Excellent solution TEDL
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 10-30-2011, 11:34 AM   #10 (permalink)
View rshep's Photo Gallery
use an impact gun, The only way I got mine out.
rshep is offline   Reply With Quote
