anybody witha wiring diagram? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2011, 08:27 PM   #1 (permalink)
Banned
View BonzoGonzo's Photo Gallery
the wires from the rear o2 sensor - 2 of them are heaters. the other 2 - 1 of them is a ground. the "hot" wire carries a very lov voltage - less than a volt.
i'm wondering if that wire goes through any plugs between the o2 sensor plug and the big momma connector, on the computer?
i plan to tear the seat out again, then the glove box, and clean all the connectors around the computer on sunday... should be fun, huh?
any help appreciated car is a 97
BonzoGonzo is offline   Reply With Quote
Old 11-19-2011, 11:18 PM   #2 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132150
View Jigg007's Photo Gallery
Late is better than never... right?
Bank 1 Sensor 2 Oxygen Sensor
As far as I can tell the O2 sensor has two wires that go to the II1 connector located in the driver-side kick panel, eventually leading to the ECU. the other two wires i presume are grounds that both ground off at the intake manifold to minimize ground loop/different voltage.
You should have battery voltage at the heating element when the ignition is set to "on", and around 3 volts when the engine is actually idling.
When I was having a bunch of issues with my fuel injectors, one of the things I did was unplug all the connectors and cleaned them too.. Not satisfied i also ran a 12awg wire directly from battery ground to multiple ground points on the engine and then to the bolt where the ECU wires are. Not sure if it actually helped at all or is 100% placebo.. but gave me something to do for a weekend!
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
Old 11-20-2011, 03:24 PM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $354053
View BMR's Photo Gallery
BonzoGonzo's been banned.
BMR is offline   Reply With Quote
Old 11-20-2011, 03:25 PM   #4 (permalink)
Avarollin?
Jigg007's Avatar
Yeah, I've noticed that after I posted the reply. Cant hurt having the information there, anyway.
The Following User Says Thank You to Jigg007 For This Useful Post:
TrailDust (11-20-2011)
Old 11-20-2011, 04:05 PM   #5 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3636250
+1 Thanks for posting up the information because it can help other members in the future.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 11-20-2011, 06:25 PM   #6 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Absolutely! Plus, I'd guess he can still get on anonymously and see your reply.
Old 11-20-2011, 08:52 PM   #7 (permalink)
Do you feel lucky?
TrailDust's Avatar
His antics warranted the nuclear option, so unless he changes his geographic location or uses someone else's computer he won't be seeing anything.
2002 Avalon XL
Old 11-20-2011, 08:58 PM   #8 (permalink)
Avarollin?
Jigg007's Avatar
Damn internet, you scary. I'll leave this be now.
