Replaced PS Pump, now leaking from hoses
I've replaced the Power Steering pump and everything seems to be in order aside from the hoses leaking. I've used a new pump and kept all the existing hoses and connectors.
The new pump came with 2 o-rings, one larger than the other. Only one seems to fit any of the connections. There was a power steering leak which caused my old pump to seize, necessitating this replacement.
Can someone tell me which rings and seals should be replaced? The guides I've seen aren't specific about this, nor were the directions which accompanied the pump. The pump also came with 2 copper washers but gave no suggestion as to where they are meant to go.
Are these seals and o-rings things I can find a local parts shop or must they be ordered online?
Cheers.
