I'm not one for typing super-cool-attention-grabbing-things, so I just post pictures... and videos, if you're into that kind of thing.
Project: Install new horns on my car
Requirements: Because they are legitimate air horns, I also need to install an air compressor and holding tank.
Item: YMT-6122 Yankee Air Horn System.
ebay
Because now my Avalon has onboard air, I also plan to put a disconnect for an air line for inflating tires or something. Even though 2.5L tank isnt much to play with.
If you look close enough, you can almost see the horns, a lot of good that chrome plating does!
Shot with the grill off.
Picture of the air compressor, pulls about 20 amps, operated by a relay in conjunction with the pressure switch on the tank, and the ignition signal from the car.
I had no idea air was measured in voltage, gosh!
Underbody-bumper shot, shows the terrible mounting spot for the air tank.
AVALON SWAGG(AH?)
A video my friend took, skip to 1:00 if you don't like ponies!
http://youtu.be/Ue8NNbtrGb0
