Cold Idle Speed Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2011, 07:22 AM   #1 (permalink)
View abhimanyu's Photo Gallery
Hello,
I have a 1996 Avalon 150k and was wondering what is the cold idle speed, and how long should the sensor keep the engine at cold idle speed?
When I start the car, it will idle at nearly 2000 RPM for about 5 minutes or more gradually coming down to 700 RPM when at operating temperature.
It seem rather a high speed to place the car in gear above 1500 RPM
Any experience or advice with this?
Regards
abhimanyu is offline   Reply With Quote
Old 11-28-2011, 02:15 PM   #2 (permalink)
Avy
Gameroom cash: $821455
View pmesfun's Photo Gallery
It should be about 1750-1500, and about 1100-1000 in gear.
Clean the throttle body and spray throttle body cleaner into the idle air control valve hole and let that soak for about 10 minutes. Pull the EFI fuse and put it back in to reset only the ECU, then start up the car. It may smoke for a moment, but that's the carbon and cleaner burning off.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
The Following User Says Thank You to pmesfun For This Useful Post:
abhimanyu (11-28-2011)
Old 11-28-2011, 03:36 PM   #3 (permalink)
Gameroom cash: $301725
View artbuc's Photo Gallery
Originally Posted by abhimanyu View Post
Hello,
Regards
Check this out. It works like a charm:
http://www.automotiveforums.com/vbul....php?t=1014511
artbuc is online now   Reply With Quote
Old 02-05-2012, 02:40 AM   #4 (permalink)
View 71GTJ's Photo Gallery
Unhappy High cold start RPM's
Could you help me locate idle air control valve hole and EFI fuse so i can try these methods, hope it works.
71GTJ is offline   Reply With Quote
Old 02-05-2012, 11:58 AM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $354053
View BMR's Photo Gallery
Look at the first pic in this thread. The IACV port is in the intake, at the bottom, just in front of the brass-colored plate. You'll have to remove the rubber intake tube to access it. That pic is from a 4 cylinder Camry, but yours will be very similar.
The EFI fuse is in the fusebox under the hood, near the battery. They're labeled; easy to find.
BMR is offline   Reply With Quote
Old 02-06-2012, 11:47 PM   #6 (permalink)
I sprayed and cleaned all intake area, no diff in cold start. Also noticed when i put it in reverse theres a clunk but in drive its smooth during cold high idle. (1,500+ RPM) What should i be most concerned with?
Old 02-07-2012, 04:10 AM   #7 (permalink)
It is NOT unusual for your car to have a cold fast idle of 1800-2100 rpm. Many people have complained about this and Toyota says this is normal. If your idle ramps down to 650-750 when engine reaches normal op temp and all other idle control functions work, eg idle increases when you turn on A/C, then your problem most likely lies in the ECU look-up tables. The fix is simple as I posted earlier in this thread.
The Following User Says Thank You to artbuc For This Useful Post:
BMR (02-07-2012)
Old 02-07-2012, 09:29 AM   #8 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Hey artbuc, I just went to that link; nice fix! I didn't before because I was on my phone and it's painfully slow. Have you done this?... If you'd do a DIY thread with some pics, I'd be more than happy to sticky it. It'd be nice to have one when this problem crops up again.
Edit: DOH!... just noticed it was you posting in that linked thread.
Old 02-08-2012, 04:33 PM   #9 (permalink)
Yes, it works great. Please use the existing link for DIY sticky-it contains theory, installation sketch and a couple pics.
Old 02-09-2012, 09:14 AM   #10 (permalink)
Sir Loin of Beef
Jack Deth's Avatar
View Jack Deth's Photo Gallery
hey art, i've been meaning to try this for a while now, and i looked at the pix, but i can't quite figure out where in the engine compartment i am .
will you please tell me what part of the compartment the ECT sensor is located in, or maybe what is is near?
Jack Deth is offline   Reply With Quote
Old 02-09-2012, 02:11 PM   #11 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
My first thought was to do that, but the pics can't be viewed without registering.
Old 02-12-2012, 09:31 AM   #12 (permalink)
Jack, if you lean in from the passenger side front tire and look down directly at the top of the coolant pressure cap, you will see the ECT sensor at about 8 o'clock (in plan view), sitting right behind the TB cover.
Jack Deth (02-12-2012)
Old 02-12-2012, 02:18 PM   #13 (permalink)
Sir Loin of Beef
Jack Deth's Avatar
i see it now, thanks art!
Old 02-22-2012, 11:11 PM   #14 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132150
View Jigg007's Photo Gallery
Maybe related, maybe not. I have an odd, intermittent issue. That sometimes on cold mornings, first start of the day, the engine will turn over and immediately drop to "hot" idle, around 650rpm, which is kinda lame when you want a warm car when you leave for work
Thought it might be a temperature sensor on the intake, not sure if it has one and where. Maybe it is part of the MAF? I looked around and kicked around some of the wiring harnesses in that area, But its too soon to see if it cured the intermittent problem.
I'll chime in too, that when the car has its correct cold idle speed, its just shy of 2krpm if its really cold outside. 1500rpm is pretty normal otherwise, 30F and above.
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
