Seatbelt Retract - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2011, 10:20 AM   #1 (permalink)
View ottogaus's Photo Gallery
Seatbelt Retract
After 215k miles, front passenger seatbelt no longer retracts. Tired of kids closing it in the door! Saw posts suggesting cleaning the belt and "clip/holder" (the part that adjusts up and down between the front and back doors). Didn't help. Also made sure the belt isn't twisted - it's not. Any suggestions? I am leary of taking the mechanism apart and trying to fix given the extreme importance of it working properly. Does the retracting mechanism just get weak over time? Replacement part is $200.
ottogaus is offline   Reply With Quote
Old 12-08-2011, 11:01 AM   #2 (permalink)
FSAE "Engine guy"
View Vlad1024's Photo Gallery
Yup, it's just a spring so it will lose effectiveness over time. Only way to fix is to replace it but i'm pretty sure you have to disassemble the whole thing to get at it.
08 tC mt
Smooth driving is comfortable and easy. It is also FAST(though not comfortable at speed). I don't care if you apex corners(everyone does) on a public road unless you suck at it(everyone). Hold a proper line or get out of my way.
Vlad1024 is offline   Reply With Quote
Old 12-08-2011, 02:11 PM   #3 (permalink)
Thanks Vlad. You or anyone else disassembled it? It does not at look like it is meant to be taken apart.
Old 12-08-2011, 07:13 PM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $354053
View BMR's Photo Gallery
My Camry's got the same problem. I tried the fix in this link, but it didn't help at all. Mine only had about one turn of preload slack in it. I'm guessing the spool assy in the pictures is what has to be replaced.
BMR is offline   Reply With Quote
Old 12-08-2011, 07:49 PM   #5 (permalink)
Unfortunately can't buy just the retract assembly and the entire belt is about $200.
Old 12-12-2011, 03:11 AM   #6 (permalink)
CRESSIDA!!!
84Cressida's Avatar
Gameroom cash: $656020
View 84Cressida's Photo Gallery
A common problem with Toyota seatbelts through the 1990s. The springs wear out and lose their ability to retract the belt. Try cleaning the belt. That has been known to help a little bit.
1994 Toyota Pickup Xtra cab 4x2 22R-E 44,000 mi
1998 Toyota Avalon 1MZ-FE 137,000 mi
2005 Chevrolet Silverado Crew Cab 49,000 mi
2006 BMW 330i Sedan 85,000 mi
2007 Toyota Camry Hybrid 2AZ-FXE 62,000 mi
As of May 17, 2011. DEATH TO SCION!
84Cressida is offline   Reply With Quote
Old 12-12-2011, 03:15 PM   #7 (permalink)
Thanks 84cressida. Belt is very clean, but I did some cleaning nevertheless. No improvement (probably because already clean). Do you have any experience with replacing the spring or having it replaced?? Or known anyone to do this? Thanks.
Old 12-12-2011, 09:44 PM   #8 (permalink)
FSAE "Engine guy"
It's not just the 90's lol.
08 tC mt
Old 12-13-2011, 12:00 AM   #9 (permalink)
CRESSIDA!!!
84Cressida's Avatar
I don't have any experience with replacing the parts, but buying a new seat belt (they don't sell the mechanism seprately unforunately) will fix the problem..until that one eventually wears out, too.
Does your seat belt retract at all? When they wear out, they should still retract the belt but you might have to guide them with your hands and help them out a bit. Do yours not retract at all? That might be indicative of another problem, since obviously there isn't supposed to be slack on the belt when a person has it on.
Old 12-13-2011, 12:14 AM   #10 (permalink)
Yes, belt retracts very slowly if jiggled and given encouragement. Likely a weak spring. I see there is a repair place in Jupiter Florida specializing in seatbelts. May give them a try.
