magnet came off of abs system during strut removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-24-2011, 10:11 AM   #1 (permalink)
View trickstar's Photo Gallery
Hello, and thanks in advance
I was changing my struts, and a small magnet inside a round plastic half dome attached itself to one of the struts that I had removed. Now my abs light is coming on.
Is or was this part of the sensor? How is it attached to the sensor? Is there a physical wired attachment to the sensor, or did this just break off? I'm considering just gooping it back into position.
Any information appreciated,
Jimmy
trickstar is offline   Reply With Quote
Old 12-24-2011, 12:05 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $354053
View BMR's Photo Gallery
The wheel speed sensors do have a small cylindrical magnet in them. From your description, it does sound like that's what it is. The plastic half-dome must've broken off the nose of the sensor. You could try gluing it back in, but I'd guess chances are low it'll work. The magnet goes inside a coil of hair-like wires, so be careful when you stuff it back in that you don't break one or scrap the insulation off. The wires have that thin varnish-like insulation. Also, be sure to get it fully re-inserted. If it's not, it might rub on the tone ring; a gear-looking thingy with teeth that the sensor sees to generate pulses as it rotates.
BMR is offline   Reply With Quote
