Crank Pully removal/Water pump Job - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2012, 09:42 AM   #1 (permalink)
View Roger1983's Photo Gallery
Hello Everyone. Im in need of some advice. I am working on a 97 Avalon XLS with 218,000 miles. I have done water pump jobs on other cars so im not new to the task.
My only problem is that I cant get the Crank Pully bolt off. I have a impact that is rated at 260 ft. lbs. and it wont get the bolt off. Any one have any suggestions? Bigger impact? Direction of rotation?
This is so frustrating. How many ft. lbs. is that bolt on there with.
Roger1983 is offline   Reply With Quote
Old 01-16-2012, 12:34 PM   #2 (permalink)
Gameroom cash: $301725
View artbuc's Photo Gallery
I feel your pain. I assume that crank pulley has been off at least one time before and you never know how much torque was used to re-install it or if someone did something stupid like use high strength Loctite. I have always had great success bumping the starter but I can't recommend that because I don't know how tight that baby is in there. Can you rent or borrow a 3/4" impact? I've read where they successfully removed the infamous Honda crank bolt (assuming you have enough air pressure). Correct torque is 159 ft-lbs.
artbuc is online now   Reply With Quote
Old 01-16-2012, 12:58 PM   #3 (permalink)
Crank Pully
I have a 92 Honda Prelude w/H22 motor and I got the crank bult off that with no problem using the same impact. Im not sure whats up with the Avalon. What direction is the rotation?
I am trying to score a 425 ft lb 1/2" impact right now. Hopefully that will have enough umph to do the job. I have a thirteen gallon air compressor @125 psi with the reguilator removed.
So it packs a hell of a punch. My current impact shakes the crap out of the motor when im torquing on the nut. But wont break the bolt lose.
Old 01-16-2012, 04:33 PM   #4 (permalink)
Its been a few years since I did mine but I'm pretty sure its lefty-loosey-righty-tighty. I'm sure someone will confirm.
Old 01-16-2012, 04:46 PM   #5 (permalink)
View nevada's Photo Gallery
should be standard rotation. right hand threads.
sounds like you need a stronger gun.
also make sure you arent using any extensions, and use the shortest socket that will fit on the bolt.
nevada is offline   Reply With Quote
Old 01-16-2012, 05:08 PM   #6 (permalink)
it lives..and spins wheel
ProjectAvalon's Avatar
View ProjectAvalon's Photo Gallery
if you still have not resolved the issue..
get a torch on the crankbolt,
i've had 500+ft lb impacts have a hard time on honda pulleys. we heat that sucker up red hot and let her rip. (you will heat up the bolt red hot before you really start heating up the pulley)
ProjectAvalon is offline   Reply With Quote
Old 01-16-2012, 05:15 PM   #7 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
standard trick is to use the starter to break it loose. get a breaker bar that reaches the ground or contacts the frame somewhere that will stop it from spinning, set it up and turn 'er over.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 01-21-2012, 07:38 AM   #8 (permalink)
View CantKillaCam's Photo Gallery
Concur with the starter/breaker bar method though it is the longest 2 seconds in auto repair. Recommend disabling the ignition prior bumping the starter.
CantKillaCam is offline   Reply With Quote
Old 02-02-2012, 10:58 AM   #9 (permalink)
View chuckoff's Photo Gallery
Sometimes it is a real pain. There is a tool made to bolt to the front of the pulley that you insert a breaker bar to hold the pulley from rotating. Brace the breaker bar against the frame and use an Impact or, 3/4 drive breaker with a 6' cheater on it. You can use an extension out from the pulley and support it with a jack stand.
chuckoff is offline   Reply With Quote
