98 Avalon Coolant Flush - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2012, 10:14 PM   #1 (permalink)
View 19Glendale's Photo Gallery
Anyone know the steps required to do a coolant flush on the '98 Avalon (not just a radiator drain and refill)? or could direct me as to where I could find it. Didn't have any luck searching on the forum.
I have a bottle of the Toyota dealer coolant and some distilled water and was thinking now's as good a time as any... want to keep this thing running as long as possible.
Any other related advice would be much appreciated.
Thanks again, the regular commenters on this forum are indispensable!
19Glendale is offline   Reply With Quote
Old 01-18-2012, 12:07 AM   #2 (permalink)
it lives..and spins wheel
ProjectAvalon's Avatar
View ProjectAvalon's Photo Gallery
i dunno about "required" but are my usual steps.
pull hoses and let drain.(you can either do it the messy way or time consuming) usually i put it all back together and replace it with water.
then run the car to cycle the remaining coolant. and drain until only water is present. then refill and bleed system.
alternately, you could pull the hoses and start the car with the outlet hose in containers/pans. i'd forsee a mess but it'd be quicker i suppose.
ProjectAvalon is offline   Reply With Quote
Old 01-18-2012, 12:49 AM   #3 (permalink)
Avy
Gameroom cash: $821455
View pmesfun's Photo Gallery
There are engine block drains on each side, one by the oil filter and I think by the egr tube at the back. Be sure to flush only with distilled water and take into account the amount of water left in the engine when doing the coolant/distilled water mix.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Tags
avalon, coolant, coolant flush
