Ok, I cleared the codes and the P0402 came back, not the 1411 I was trying to figure out earlier.
I took the VSV off and ohmed it out. It ohmed good. I then applied 12VDC across the terminals and you could hear it switch, so I assume that it is good.
So now I've taken the part off that measures the EGR opening. I ohmed this and pushed the rod up and down. The resistance changed, but there was one spot in the middle where it felt like it was going over a bump. This doesn't seem right. This part is only about $35 so I might take a chance with replacing it.
The VSV is $100 and the EGR is $175, I cannot afford to shotgun those parts.
I really hope that it is the measuring device.
