Yeah, what fourwheeler said above.
The heater resistance will probably be quite low. Power = V^2/R. Rearranging terms; R = V^2/Power. Looking at the aftermarket ones, wattage is typically 50 or so. Assuming 12 volts, resistance calculates out to be 2.88 ohms. So if you see anything over 4 or 5 ohms, something's probably wrong.
