Headlights/interior lights flickering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2005, 09:47 PM   #1 (permalink)
Skooter's Avatar
View Skooter's Photo Gallery
I have a 2000 Avalon XL I bought used about 6 months ago. Dealer checked TSB's at my last oil change (57K miles) nothing showed up. I've only noticed this since it's gotten colder out. Never noticed in Spring (when I bought it) or the summer, just this winter. Seems to stop once the car has warmed up. Dome light, dash lights, headlights, etc. all pulsate. Of course it wouldn't do it at the dealer, when it was warm. It's not affected by engine revs and it happens with headlights set to auto or on. Reading lights flicker even with headlights off. I read somewhere else that maybe the automatic headlight circuit was at fault. Anyone else have this problem? Any ideas what's causing it?
TIA
Skooter is offline   Reply With Quote
Old 01-12-2005, 10:08 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
try cleaning your grounding points. and a grounding kit (store bought or self made) can help as well
^ and leaving it that way!
Old 01-14-2005, 12:11 PM   #3 (permalink)
Skooter's Avatar
So that's the the total knowledge of the group...check my grounds?
Old 01-18-2005, 04:33 PM   #4 (permalink)
Corsa!
Galvatron's Avatar
View Galvatron's Photo Gallery
I would reccomend checking all ground points, and connections in general as well. Something like this has to be a crappy cable or ground somewhere. Check the main cables going to the battery and all connection points.
1992 Tercel DX, 3E-E/3AT
1992 Paseo, 5E-FE/5MT
2007 Suzuki SV650S
http://www.rent-a-tech.org/wordpress
Galvatron is offline   Reply With Quote
Old 01-19-2005, 10:29 AM   #5 (permalink)
View karugs's Photo Gallery
You could also check if each light bulb is starting to go. But that would be cumbersome.
Seriously, checking the grounding is the most logical, and easiest, step. Flickering lights at cold (winter) indicates electrical--possibly a loose connection, bad ground or weak battery.
karugs is offline   Reply With Quote
Old 01-20-2005, 12:22 PM   #6 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I have the same problem, but I'm almost sure its my battery. The amount of things I have to running and also the fact that it's kinda old.
http://www.xclusive.bz
