Originally Posted by dmem1
Terrastrife,
In your opinion, is it worth putting in the TRD s/c?? Thanks to both of you for your help with this!
D
It's a pretty quick gain of power.
Your 2 options would be this and as he said, turbo. Turbo is easier to add hp because you can run higher boost and get more power. But the problem is, if you run too much boost w/o upgraded internals, you run the risk of blowing your engine.
S/c is a little harder to get more power after but it is safer, meaning you aren't as likely to blow your motor, but it's still possible.
