Does the avalon have dual compressor? Only the passenger side gets cold air - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2005, 10:11 PM   #1 (permalink)
View Dannieboiz's Photo Gallery
I'm not sure what's going on but I'm getting cool air from the driver side only but the passenger side is cold. Does anyone knoe what's going on?
Dannieboiz is offline   Reply With Quote
Old 05-28-2005, 12:02 AM   #2 (permalink)
View fj40supraman's Photo Gallery
Don't be crazy, there is only one compressor. Hate to be a smart ass but are the vents open? Does the heat come all the vents?
Current- '97 Avalon w/ 100k
'99 Avalon w/ 200k, sold to friend (1MZ-FE)
'86 4-Runner- wrecked and sold (22R-E)
'85 Corolla- engine lost compression=junkyard (4AC)
(3S-GTE MR2 or 2JZ-GTE Supra as soon as eng. degree pays off)
fj40supraman is offline   Reply With Quote
Old 05-28-2005, 01:09 AM   #3 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $592557
iTrader Score: 7 reviews
View xpeed's Photo Gallery
What year's your avalon? If it's the 2005, have you checked the temperature climate control? If there's still problems, get it checked out. A vent might not be opened all the way or there's a hole.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 06-03-2005, 01:48 PM   #4 (permalink)
It's an 01 XLS, I have dual climate control and yes all vents are open. The 2 driver side vents only pushing cool or often just regular air (no ac). I've tried all settings, and yes heat does come out the same for all vents. I'll just bring it in. I'm also noticing my tempt going 3/4 way up on hot days.
Old 06-03-2005, 06:57 PM   #5 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Sounds like the door actuator for the passenger side climate control isnt working. Ive seen that problem on just about every car other than toyota so far. Let us know what they find.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 06-03-2005, 09:36 PM   #6 (permalink)
what does the door actuator have to do with the a/c especially when it's on the passenger side and the problem is the driver side.
Old 06-05-2005, 08:35 AM   #7 (permalink)
View 05Limited's Photo Gallery
Temperature readings on the new cars are controlled by an infrared sensor. Could be that one sensor is defective. Also, if the Avalon is like some of my previous cars the AC/Heater has a mixing box in the dash with a door/damper going to each side of the car. These doors are usually vacuum controlled or sometimes electric. It might be that one side has a vacuum leak or a bad motor and is stuck.
05Limited is offline   Reply With Quote
