Code P0441 & P0446 (EVAP) HELP 1998 Avalon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2005, 09:49 AM   #1 (permalink)
View zamboni1996's Photo Gallery
Has anyone else experience this code. I have a 1998 toyota avalon (110,000 miles) and engine light keeps coming on after a week or so. I keep resetting it and keeps coming back. Where do i start??? Also looking for driver sun visor (tan). Thanks
zamboni1996 is offline   Reply With Quote
Old 06-10-2005, 01:38 PM   #2 (permalink)
View jjanari's Photo Gallery
P0441 refers to "improper purge flow." It is not uncommon to see it in conjunction w/P0446. but before you get into how to fix it, check this link out. I have a 96 camry that had P0441 and, after calling toyota customer service, was able to get them to pay the bill ($750.00 to replace a duty valve and charcoal cannister). see if your car is covered.
http://www.epa.gov/compliance/resour...aa/toyota.html
jjanari is offline   Reply With Quote
Old 10-13-2006, 09:56 PM   #3 (permalink)
View m44offroad's Photo Gallery
i belive toyota covers the evap parts for 8years or 80000miles, usually you will see p0440 p0441 and p0446 together but before anything replace your gas cap and besure to tighten it down when you gas up the vehicle, 90% of the time with those codes either a loose gas cap of bad gas cap gasket is the problem
m44offroad is offline   Reply With Quote
Old 10-16-2006, 12:18 PM   #4 (permalink)
View drewd's Photo Gallery
Thumbs down P0446 code in an Avalon
I have a 1999 Avalon and the P0446 code has been reoccurring for the past year. Once I drove it up in to the mountains (I'm at sea level usually) and the code reset itself and stayed off for about a month. Since then I have been resetting it myself but it has been returning quicker each time. I'm not sure if the VSV is in the engine compartment or at the gas tank - any help would be appreciated.
If it is the charcoal cannister can it be blown out with compressed air?
thanks,
Drew
drewd is offline   Reply With Quote
Old 10-16-2006, 06:57 PM   #5 (permalink)
View toyomoho's Photo Gallery
P0466. Might be a canister leak, defective VSV valve or hoses. Just guessing these parts may be in the engine compartment area between the passenger’s side shock tower and firewall.
Old 10-17-2006, 09:15 PM   #6 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
p0446 = Charcoal Canister 90% of the time
BadChicken is offline   Reply With Quote
