1997 Avalon dash lights - Toyota Nation Forum : Toyota Car and Truck Forums
Avalon 1st Generation (1995-1999) Specific discussion of the first generation Toyota Avalon
post #1 of 19 Old 04-10-2007, 08:58 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Hi, New Avalon owner here. Actually not so new Avalon (1997) that my mother donated to my teenage daughter. I did the front stut mounts and one front sway bar link last weekend and that tightened up the suspension feel considerably. I ordered rear sway bar links as those are quite loose as well.
Next, I need to replace a couple of instrument cluster lights. Does anyone have the removal procedure for this car? I see the normal two screws for the top of the cluster hood, but the bottom attachments seemed to be buried by other trim pieces?
Thanks
Ross_t is offline
post #2 of 19 Old 04-10-2007, 09:08 PM
Quoted: 0 Post(s)
you need to take off the radio trim piece and the left hand side ac trim piece.
for the radio piece, it's easy if you stick a screwdriver in at the bottom and pry up. the left hand ac piece is easiest to remove by sticking a screwdriver at the side by the instrument cluster.
next, you remove the 3 screws that were visible before you took the trim pieces off, and then there should be three more on the black instrument cluster surround after you take of the trim pieces. after those are out, the black surround comes out, and you have access to the clusters 4 bolts.
aigochamaloh is offline
post #3 of 19 Old 04-11-2007, 06:02 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Great, thanks. I'll try this out this weekend.
Ross_t is offline
post #4 of 19 Old 04-13-2007, 12:24 AM
Official Member
steve326a's Avatar
Quoted: 0 Post(s)
Gen1
I need to do some bulb changing in my cluster as well. What are the bulbs used? Are they the standard 194 type?
Thanks,
Steve
** 97 XLS With All The Toys! My Baby! **
** Enjoy & Long Live Your Avalon! **
FOR SALE MOVING! $3400 OR BRO
steve326a is offline
post #5 of 19 Old 04-13-2007, 12:43 AM
Quoted: 0 Post(s)
194 bulbs for the cluster, i believe 3 of them. the warning bulbs, gear selection bulbs, etc are 89's.
post #6 of 19 Old 04-13-2007, 12:47 AM
Quoted: 0 Post(s)
if you want a cool lexus like look, you might want to get some inverted leds. these are leds that don't have hotspots...
this is my cluster
post #7 of 19 Old 04-13-2007, 01:11 AM
Official Member
steve326a's Avatar
Quoted: 0 Post(s)
Gen1
Wow, looks good. I noticed something though. Is your gas tank full? If so, do you have the same problem as I do where the gauge never hits full but just above 3/4? Anyone else have that problem? Is it the gauge itself or the sending unit?
Thanks,
Steve
post #8 of 19 Old 04-13-2007, 01:22 AM
Quoted: 0 Post(s)
no my gas tank isn't full. you can see my trip meter, 88 miles since fill up...my meter goes all the way up when full...
i do have this problem in my mr2...it is the sending unit. it's probably easier to test this in the avalon. just pull up the backseats and take out the fuel pump, and access the sender. use a multimeter and check the resistances...
i've never done this to my mr2 since i would have to drop the fuel tank and that is no fun...i live with it
post #9 of 19 Old 04-13-2007, 01:57 AM
Kingdom934's Avatar
Quoted: 1040 Post(s)
this is my cluster
Wow...where did you get those inverted LEDs?
Kingdom934 is offline
post #10 of 19 Old 04-13-2007, 02:07 AM
Quoted: 0 Post(s)
i just got some off of ebay. search 194 inverted white...
my gauge cluster has gone through many changes...
this was my cluster shortly after i bought my car. i was 16 at the time and was mod happy...unfortunately, it was very ricey...
i've toned down to the classy modifications now...
i actually also upgraded to hids, and they're nice. i made a thread today with pictures as well...
http://www.toyotanation.com/forum/t187913.html
post #11 of 19 Old 04-13-2007, 06:26 AM
NFS: Most Wanted
toyosupra_87's Avatar
Quoted: 0 Post(s)
Canada cluster
I got the same cluster the only problem(dislike) about them is:
1. its missing the high beam symbol
2. its missing the windshield washer symbol.
Than the rest I like.
my buddy bug me the guage is MPH and not KMPH.
I still that cluster.
Interesting with LED ligths, might do that with my MKIV dash.
Steve, about the fuel gauge its almost the same problem. I fill up the tank and guage SLOWY moves and stay between 3/4 and full. I park it in the drive way and than the next morning when I head to work, turn on the car it goes up to full. Why is that? why so long? would it be a bad connection?
93 Jeep Grand Cherokee Laredo/87 Toyota Celica GTS/87 Toyota Supra Turbo - sold it
1995 Toyota Avalon XLS - Awsome car, Still ALIVE
1994 Toyota Supra TT - under contruction/rebuild
1997 Dodge Caravan-family van/winter beater
toyosupra_87 is offline
post #12 of 19 Old 04-13-2007, 08:10 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
nice look, I bought a pack of 194's for a fast fix. But might try this sometime.
Ross_t is offline
post #13 of 19 Old 04-13-2007, 09:31 AM
Quoted: 0 Post(s)
i'm 20 now...
post #14 of 19 Old 04-13-2007, 11:06 AM
Quoted: 0 Post(s)
good, so you were able to change them. i hope my instructions were clear enough...
post #15 of 19 Old 04-13-2007, 02:31 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Hi, no I plan on doing them tomorrow, plus the rear sway bar links. Your instructions are just what I was looking for. I don't like prying on plastic trim panels without some knowledge of where to attack them! thanks again!
Ross_t is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Avalon Forum > Avalon 1st Generation (1995-1999)
User Tag List
Linear Mode Linear Mode
Back
